Is it okay to reflow an SX28AC/SS after it's programmed ?
Bean
This may be a stupid question...But
If I have a programmed SX28AC/SS chip, and I run it through a reflow oven could it lose the program ?
I know it's best to program them "in-system", but I want to sell pre-programmed chips.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95 http://www.parallax.com/detail.asp?product_id=30012
Product web site: www.sxvm.com
"It's not getting what you want, it's wanting what you've got."
Post Edited (Bean (Hitt Consulting)) : 6/5/2005 4:08:33 AM GMT
Bean.
As forrest said, there shouldn't be a problem. The reflow process itself would not hurt the non-volatile memory this is done all of the time, and
I can't imagine the reflow process "flipping-bits". I think your safe.
Beau Schwabe
IC Layout Engineer
Bean.
-dave
This is not a sig. This is a duck. Quack.
Not a problem. Our BS2SX, BS2pe, BS2px, BS2p24/40, SX-Keys, Ping))) sensors, and countless customer SX applications are programmed prior to PCB mounting. We don't tie many failures to having pre-programmed SX chips. Usually our problems lie with solder bridges, PCB manufacturing issues or improperly placed components (not failure of the SX due to pre-programming).
Funny thing is that when Ubicom was first created (as Scenix) the sales people used to tout the advantages of in-system programming of the SX. The benefits of programming a toaster on the assembly line still ring in my head. . .Most of the major applications I know of which use the SX are pre-programmed. In fact, our programming person handles several customer accounts. By the way, she just left to pursue some career goals. If you are looking for a job programming chips contact our HR department. We'll keep you out of trouble.
Bean, go for it.
I don't know if he is talking about pre-programming or the job offer.
But, just in case you are having a "slow" day, that is opportunity at the door Bean....
Jack
I am interested and I will explore it.
Bean.
Still, if you're not satisfied yet, you can try reflow a programmed flash ROM onto the board and then read it out via Propeller or a special I2C driver module (which you read out the whole thing via PC's USB).
Just be careful around X-ray inspection, though (it won't apply to smaller-geometry flash ROM, as I have heard that few such chips are made by X-ray masked lithography or EUV lthography so it's already radiation-hardened...) Just don't do X-ray inspection on OTP memory (the EEPROM in opaque cover) at all - it's the way I erase the OTP.
Bean, you should be fine as-is. They're already designed to survive the punishment of heat without any data loss.
But for other memories, I doubt it would be a problem. For some chips (such as OTP-based ROM), I just leave it unprogrammed, piror to X-ray exposure (such as radiological
BGA / SMT soldering inspection).
