Help with battery tester for robot?? — Parallax Forums
Jay-BobJay-Bob Posts: 5
edited 2005-07-29 17:51 in BASIC Stamp
Hello all,
I am building a robot Tank with 2 STAMPs, one on the Tank end and one on the Remote end. I am going to build transceivers on each side, so I can relay information back to my STAMP in the Remote for a status readout on the Remote Control.
I want to have the ability to test the status of the batteries in the Tank and transmit that back to the Remote. I have found the ADC0831 to test the battery status digitally and then I can send it back serially to the Remote. I was wondering if it would be easier to use a resistor/cap diagram to test the voltage? or would it be safer (for the STAMP) to use the ADC?
I am going to use 9.6V NiMH batteries with a 5 voltage regulator for my STAMP and TTL circuits and a 3V regulator for the motors. I think that the 9.6V should last a little while under these conditions, so I would want to relay back to the Remote the status as the voltage drops. I will use some LED's on the Remote to give me a status of Voltage.
I studied Electronics and MicroControllers (PICs) in college for two years, I know some, but not all...... will you guys help me out??
J
US Army
Mannheim, Germany
    edited 2005-06-04 14:48
    I'd stick with the ADC0831 since it will give you better precision than an RC circuit, but it's a 5-volt device so you'll want to run the raw battery voltage through a precision divider to take to the input of the ADC0831.
    Thanks for serving ... I was a Radar/ECM guy in the USAF.
    Jon Williams
  • Jay-BobJay-Bob Posts: 5
    edited 2005-06-04 14:55
    I enjoy it... wish I would have joined the Air Force, but hind sight is 20/20 smile.gif LOL
    What would you recommend for the voltage divider?
    a POT?
    but won't the output fluctuate due to voltage drop? so therefore, it won't be a true divider?
    J
    edited 2005-06-04 15:02
    You want to monitor the battery voltage, right? I would use two precision resistors (say 50K each) and take the center tap to the input of the ADC0831. When your battery is fully charged you should get about 4.8 volts to the ADC. If you're using your regulated 5 volts as the ADC reference, 4.8 volts would give you 244 (4.8 / 5.0·x 255) counts from the ADC. Let's say you want to do something when the battery voltage drops below 7 volts -- you'd read your ADC periodically and when it fell below 178 you'd do something about it.
    Assuming you use a divider with both resistors being the same value, you can calulate the counts from you ADC for a given voltage like this:
    · (raw_volts / 2) / 5.0 x 255
    So from my example above, (7 / 2) / 5 x 255 = 178
    Jon Williams
    Post Edited (Jon Williams (Parallax)) : 6/4/2005 3:05:02 PM GMT
    edited 2005-06-04 15:52
    If you do want to try the RCtime route, there's a tutorial here...
    http://www.emesystems.com/BS2rct.htm#B_voltage
    Tracy Allen
    www.emesystems.com
    edited 2005-06-07 06:52
    Thank you so much Jon!!!!
    Putting two 50K between the 9.6V and GND will give me the situation that I want, plus will keep me from dropping very much current out of the batteries....
    Thanks again,
    J
  • Brian CarpenterBrian Carpenter Posts: 728
    edited 2005-07-29 15:08
    jon,
    so based on your equation. (raw_volts / 2) / 5.0 x 255
    if i am using a 11.1 v lithium battery that i want to monitor the math would be. ( 11.1 / 2 ) / 5.0 x 225. is this correct? for this voltage would i also use the same 50k resistors?
    edited 2005-07-29 15:14
    jay-bob, could you post how you make that circuit. what pins and where the resistors go?
    edited 2005-07-29 15:20
    In your case you should use a lop-sided divider.· If you use a 100K and 50K (the 50K is on the "bottom") a voltage of 11.1 volts at the "top" (to the 100k) should give you about 3.6 volts at the junction -- this falls below the 5v reference you'd typically use for the ADC0831.· Adjust the equation like this:
    ·· (raw_volts / 3) / 5.0 x 255
    Jon Williams
    edited 2005-07-29 17:21
    Jon, i am sorry for the ignorance. is it possible to show me a diagram of how these resistors wire with the taps for power?
    Here it is.· Note that if this doesn't make sense, you may want to work on your electronics skills a bit before proceeding (or get a friend to help).· We'd hate to have you misconnect something and damage your BASIC Stamp.
    Note that V_Mon is your 11.1 volt input.· If you need more information on the ADC0831 this article may help:
    http://www.parallax.com/dl/docs/cols/nv/vol6/col/nv118.pdf
    Jon Williams
    Post Edited (Jon Williams (Parallax)) : 7/29/2005 6:00:15 PM GMT
    523 x 334 - 12K
