Photocell help
i am currently trying to run a program that when the photocell senses diffrent light shades it gives out a value and makes a sound when it gets to that certain value. I have the values of the photocell working but all i need to do now is get the speaker to turn on when the value reaches the desired number.
' {$STAMP BS2}
time VAR Word
loop:
HIGH 2
PAUSE 100
RCTIME 2, 1, time
DEBUG HOME, "time = ", DEC5 time
IF time= 100 THEN sound
GOTO loop
sound:
FREQOUT 15, 1000, 1000
' {$STAMP BS2}
' {$PBASIC 2.5}
Photo·········· PIN···· 0
Spkr··········· PIN···· 1
AlarmLevel····· CON···· 500
Tone··········· CON···· 440
light·········· VAR···· Word
Main:
· GOSUB Get_Light
··DEBUG HOME, "Light = ", DEC light, CLREOL
· IF (light > AlarmLevel) THEN
··· FREQOUT Spkr, 100, Tone
· ENDIF
· GOTO Main
Get_Light:
· HIGH Photo
· PAUSE 5
· RCTIME Photo, 1, light
· RETURN
I've also attached a schematic that works with the Get_Light surbroutine.· Note that in your original program you use "LOOP" as a label name -- LOOP is now a PBASIC keyword so it shouldn't be used in this manner (you'll get an error if you enable 2.5 syntax).
Jon Williams
There's lots more you can do with photocells and speakers. Try the activities in chapters 7 and 8 of What's a Microcontroller. It's available for free download from www.parallax.com -> Downloads -> Stamps in Class Tutorials.
Regards, Andy
Post Edited (Andy Lindsay (Parallax)) : 6/3/2005 3:33:04 PM GMT
