2 bit access — Parallax Forums
2 bit access
Nightrider7731Nightrider7731 Posts: 46
edited 2005-05-31 21:38 in BASIC Stamp
Is there·any symbol that can be used to reference 2 bits of a byte?· I'm controlling 4 pairs of bits with the requirement that only one bit in each pair can be on (1).· I can label each bit and programmatically affect each pair one bit at a time, but I'd love to be able to reference and set them to %01 and %10 in a single call.· All I can find are symbols for 4 (Nib) and·8 (low/highbyte)·bit values.
Thanks!
    edited 2005-05-31 03:18
    Hello,
    ·· There are 2 ways you could go about this.· The first would be to use a NIB variable and mask the bits you aren't using.· The other way would be to reference the individual bits.· For example:
    bitVal = index.BIT0
    OR
    index.BIT1 = IN1
    index.BIT2 = IN2
    Something like that.· But basically there is BIT access, not just NIB and BYTE (And WORD).
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
    Post Edited (Chris Savage (Parallax)) : 5/31/2005 3:25:46 AM GMT
  • Nightrider7731Nightrider7731 Posts: 46
    edited 2005-05-31 05:19
    Currently I've aliased each bit in·the byte...
    TARGETCONTROL···· VAR Byte····· 'control pointer for all fire/popup code
    Player1TargetUp···· VAR TARGETCONTROL.BIT0
    Player1TargetDown·· VAR TARGETCONTROL.BIT1
    Player2TargetUp···· VAR TARGETCONTROL.BIT2
    Player2TargetDown·· VAR TARGETCONTROL.BIT3
    Player3TargetUp···· VAR TARGETCONTROL.BIT4
    Player3TargetDown·· VAR TARGETCONTROL.BIT5
    Player4TargetUp···· VAR TARGETCONTROL.BIT6
    Player4TargetDown·· VAR TARGETCONTROL.BIT7
    ... and I control each 2 bit value pair bit by bit.
    Player1TargetUp = 1
    Player1TargetDown = 0
    ···· and
    Player1TargetUp = 0
    Player1TargetDown = 1
    There is a separate controller for each motion on each target, so simply turning a single bit value·on and off doesn't work in this case.· The byte is being passed to '595 to do the work.· Actually several 595s are chained together, but that doesn't matter.· I was looking for a cheap (code wise) way to alias 2 bit blocks like this...
    Player1Target···· VAR TARGETCONTROL.2BIT0··········· ' 2BIT0 being a fictional symbol of course [noparse]:)[/noparse]
    Player2Target···· VAR TARGETCONTROL.2BIT1
    Player3Target···· VAR TARGETCONTROL.2BIT2
    Player4Target···· VAR TARGETCONTROL.2BIT3
    TargetUp···· = %10
    TargetDown = %01
    ... and then manipulate TARGETCONTROL by ...
    Player1Target = TargetUp
    Player1Target = TargetDown
    ... and then shiftin TARGETCONTROL.· I guess I'll just stick to the Bit manipulation.
  • KenMKenM Posts: 657
    edited 2005-05-31 06:10
    If I understand what you are trying to do, Chris's suggestion of masking bits·will allow·you· to process each player as follows.
    Or perhaps you could explain fundamentally what you want to do?
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    TARGETCONTROL   VAR Byte         'define byte TARGETCONTROL
    TARGETCONTROLm  VAR Byte         'create a copy of TARGETCONTROL
    Playerup1       VAR Bit
    Playerdwn1      VAR Bit
    Playerup2       VAR Bit
    Playerdwn2      VAR Bit
    'once you have the value of target control execute code below to act on
    'the status of Player1, Player2, Player3 etc.
    TARGETCONTROL = TARGETCONTROL & %00000011     'mask bits 0 & 1 (player1 up & down)
    SELECT  TARGETCONTROL
      CASE %01
      'do your code based on Player1up = 1
      'and Player1dwn = 0
      CASE %10
      'do your code based on Player1up = 0
      'and Player1dwn = 1
    ENDselect
    TARGETCONTROL = TARGETCONTROLm                'reload TARGETCONTROL with original value
    TARGETCONTROL = TARGETCONTROL & %00001100     'mask bits 2 & 3 (player2 up & down)
      CASE %01
      'do your code based on Player2up = 1
      'and Player2dwn = 0
      CASE %10
      'do your code based on Player2up = 0
      'and Player2dwn = 1
    ENDselect
    Post Edited (KenM) : 5/31/2005 6:13:22 AM GMT
  • Don BuczynskiDon Buczynski Posts: 31
    edited 2005-05-31 14:27
    Two bit reference·symbols;·(how about·TWIT),·would be a useful addition·to a future version of PBasic.·I've needed·that functionality to generate four color states·using·two I/O bits and a red/green LED; red, yellow, green and off.··The multiple bit command method is·workable, but·not the best use of the·Basic Stamp·code space.···
    Don Buczynski
    http://www.buczynski.com
    edited 2005-05-31 15:59
    Nightrider7731 said...(Trimmed)
    TargetUp···· = %10
    TargetDown = %01
    Hello,
    ·· The immediate problem I see with what you're wanting to do, is you're trying to assign a 2-bit value (TargetUp) to a 1-bit variable (Player1Target).
    Chris Savage
    edited 2005-05-31 16:33
    Use math to map a nib to a byte, each bit in the nib becomes two bits 01 or 10 in the byte...
    ps = %1001 ' 4 bits, one bit for each playertarget, set bits as desired for target up, down.
    ' then mathematically create the following
    stateOfPlay = (1 << ps.bit0) + (4 << ps.bit1) + (16 << ps.bit2) + (64 << ps.bit3)
    ' that creates the byte, %10010110 to go with nib %1001
    ' to send to the controller
    Tracy Allen
    www.emesystems.com
    edited 2005-05-31 16:51
    Chris Savage (Parallax) said...
    TargetUp···· = %10
    TargetDown = %01
    Hello,
    I was creating a ficticious 2 bit symbol (see comment on Player1target) that would solve my problem of assigning a 2 bit value to it.
    edited 2005-05-31 17:05
    Remember that Nibs and Words are not native microcontroller data types, so the BASIC Stamp has a lot of underlying code to deal with them. Adding TWITS would be no different, and what you might find is that you consume more code space than expected because of the underlying code required to deal with a non-native two-bit variable type.
    Jon Williams
    edited 2005-05-31 18:09
    Take a look at this post of someone asking the same question, there are fragments of SX/B code you may find helpful that should translate to the Stamp easily.
  • nick bernardnick bernard Posts: 329
    silly jon twits are for kids...
    i've always been a fan of shifting, perhaps this method suits you
    'unverified
    playerdata VAR Word
    Main:
    GOSUB target_routine
    FOR idx = 0 TO 6
    playerdata >> 2
    next
    '... several lines later
    target_routine:
    SELECT playerdata // 2
    CASE 0
    'do that thing
    CASE 1
    'do that thing
    CASE 2
    'do that thing
    CASE 3
    'do that thing
    ENDSELECT
    Byte walks into a bar and orders a pint. Bartender asks him "What's wrong?"
    Byte says "Parity error." Bartender nods and says "Yeah, I thought you looked a bit off."
