Will this do what I think
I would like to start out today by saying· ”YOU GUYS ARE GREAT” you really sound like a learned and experienced group. I really appreciate having a place to ask questions and get good answers usually with in hours if not minutes.
Thank You Everyone !!!!
If I include this code in an SX/B program as I think I understand it, this would turn on the pull up resistors for RA.2 and RA.4. Am I correct?
Start:
· PLP_A = %1010
I have downloaded all the SX/B documentation I could find, and I have the books that came with the kit, but seem to have a hard time understanding all of it.
Are there any books out there that are solely writer for Pbasic, or even just basic? Say something easier to learn from with more extensive explanations and examples.
Thanks again
Mike W
Start:
· PLP_A = %1010
Thanks again
Mike W
A zero in that register activates a pull-up, so PLP_A = %1010 actually activates the pull-ups on RA.0 and RA.2.
A lot of SX/B names match those in the SX so the documentation from Ubicom will always be useful.· And don't forget to checkout the books from our pals Guenter and Al (references are in the help file).
Jon Williams
Dallas, TX· USA
You might want to check, because I don't know if SX/B requires you to manually deal with the mode register or not.
If you must, then prior to setting PLP_A, mode M must be $0E for the SX28, and must be $1E for the SX48/52.
Perhaps the compiler already does this for you. However, it's still good to know in case you tackle the assembler.
Have fun,
Peter (pjv)
Start:·························· ;Start:
· MODE $0E······················ ;· PLP_A = %1010
· MOV !RA,#%1010···············
Jon Williams
Dallas, TX· USA
I wasn't sure; guess I could have checked, but it is good in anycase to have folks aware of the different mode requirements for theSX28 vs SX48/52.
Thanks for clearing that up.
Peter (pjv)
Jon Williams
Dallas, TX· USA
