Power for Servos from SX Tech Tool Board
John Kauffman
As you guys know, I am developing a course for kids that are comfortable with STAMP and want to try SX. The course focusses on redoing the WAM activities with SX/B. THen in a later course we will start them on Assembly Language.
I am now planning the servo sections and the question arises: WHat is the best way to power the servos when using a SX Tech Tool board? (Logic signal connection is not a problem). There is no Vin like Homework board or servo headers like BOE. They are using the Parallax wall wart of 7.5 volts, but there is no good connetion point.
The kids have bought WAM and will buy SX Tech TOol Kit for this course. I don't want to hit them with additional cost for this course.
My ideas to date:
- Solder leads to the female power jack on the board and attached leads to the servo black & red
- Power servos from a WAM board sitting nearby (servo red and black to Vin and Vss, servo white jumpers over to SX Tech Tool board)
- Power the servo from a 6 volt battery off to the side
- Find or make a Y shaped splitter (one female to two male) to attach to the wall wart male that would give·an extra output that could be hooked to the servo power lines.
- (My favorite, from the days when you had to hack a phone line in a hotel to connect a modem): Two·safety pins stuck through the insulation of each conductor in the wall wart output line and the servo red and black leads hooked into the the closure snap of the safety pin
You guys have any other suggestions (remember, no extra components beyond WAM and SX Tech Tool Kit)?
My ideas to date:
Jon Williams
Dallas, TX· USA
- Vdd and Vss on the SX Tech Tool header socket?
- The "regulation" voltage that is coming out of the wall wart (7.5 volts) at the female power in jack?
Also, why is "just for experimenting" an issue? Is it because:
- We would expect short periods of time that the servo is powered by only 5 volts which is lower then servo's spec?
- We woudl expect short periods of time and that reduces the time that the Sx Tech Tool regulator has to carry the higher current of the board + the servo?
- Other?
THanks.
Am I wrong, or aren't servos spec'd for 4.8 to 6.0 volts? Why would 5vdc be a problem? Okay, you don't get quite as much torque as at 6vdc, but the BOE-Bot is really not that heavy.
The regulator on the SX-Tech board is fairly beefy and has a heat sink; I think it will handle the SX and a couple servos without problems.
Jon Williams
Dallas, TX· USA
I use 5V regulated for RC style servos all the time. They work great with it.
Thanks, PeterM
Would the 'Development Board' be a good substitue for the 'SX Tech Tool board' for a person that is just getting started with the SX tool kit?
I'm I going to want to start out using the 'SX Tech Tool board' and then move to the 'Development Board' after I have the basics down?
Russ
Jon Williams
Dallas, TX· USA
Servo connections to the SX Tech Tool board are covered in Daubach's 2 ed. page 427 (Application - SX on BoeBot frame)
Jon Williams
Dallas, TX· USA
