Has anyone tried to make a digital tachometer with thier stamp?
I have a bs2sx and hope to make a digital tachometer for my vehicle. I think it can be done using the count command, but was hoping to find out if it will work or if someone has done it. My biggest worry is the stamps ability to sink the incoming current. I haven't measured the signal yet, but I would think it would have to be pushing the 30mA? limit. I'm also worried about possible spikes that won't be seen under normal circumstances. If anyone has ever tried this or has any insight to the situation, please let me know.
you can put multiple magnets on one wheel/pulley and count more than one per revolution...but just be wary that the stamp might not be fast enough to count 36 switches when the pulley is moving at 5000RPM already!
I've got a project on the shelf (waiting for better weather) that I'm planning on interfacing to my Jeeps' OBD2 interface and picking off live data.
I've only build the circuit to 'talk' to the interface chip....haven't gone past that!
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
What make & model year is your vehicle?
Thanks for the replies!·· I didn't think about attaching my own sensor. That's a good idea that should eleminate all of the current worries.
KenM
It is actually for a friend's racecar. It's a Chevy 350 with a MSD ignition box.
Thanks Again
So, when you go to power your setup (after realizing how you want to read/pick-off the tach data) then you'll have to go about setting up some filters and such to protect against coil collapse..etc...
lightsout:
A voltage divider may not be good enough. The voltage in a car can go from 12V up to 14 or even 16V if you have a HOT alternator.
Run a regulator off of the battery (ACC switched). This way, regardless of how much the voltage varies, you'll have a nice steady supply...AND, it offers some protection as well. Not much...but some! lol
Steve
Brad
