Connection/Identification problem
Hello, I'm trying to interface with a BS2p40, using the BS Editor v2.1.· I get Loopback and Echo, but no Device Type.· When I try to load code onto the stamp, I get the error box "No BASIC Stamp found."· The tutorial that I have suggests that the stamp has been found, but that it may not be powered.· I checked the power to Vdd and have +5V.· Is there anything else that I can check?
Thanks in advance.
Don
Thanks in advance.
Don
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
pin1 = -5.24V
pin2 = -10V
pin3 = 0
pin4 = 0
pin37 = 5V
pin38 = 5V
pin40 = 9mV
The caps are in place, following the attached schematic.
I spoke to technical support, but they said it sounded like a bad stamp.· I checked another board (essentially the same), and had the same problem.· I am more likely to believe that I'm doing something wrong rather than 2 stamps are both bad.· Has anyone else experienced a similar problem?
Don
·· Are these boards that you build yourself that you cannot get the Stamp to program on?· Do you have any Stamps that you have programmed on these boards before?· Or, have you successfully programmed any Stamps on this computer before?
Chris Savage
Parallax Tech Support
csavage@parallax.com
Post Edited (Chris Savage (Parallax)) : 5/4/2005 2:48:45 PM GMT
Don
Don
Chris Savage
Don
·· Given the information you have provided I would suspect the board.· It's highly unlikely that you have more than 1 brand new BS2P40 that are bad.· Perhaps you could re-construct just the programming parts (caps and DB9) wired to a breadboard with no other circuitry connected, and see if you can identify the Stamp.
Chris Savage
Don
·· Without seeing the board I wouldn't even venture to guess.· It could be a be something in the communications circuit.· It would be difficult to verify that without bypassing the capacitors in the circuit.
Chris Savage
Don
·· Yes, I do have ExpressPCB.· E-Mail me the layout and I will take a look at it tonight.
Chris Savage
·· After looking at your PCB Layout, a fellow Tech and I have determined that your problem is you have shorted the /RES line to Vdd.· This is a bad thing since it prevents the Stamp from resetting, which is necessary for programming.· Normally the /RES line is internally pulled high (This is in the schematic), so you wouldn't need to do that anyway.
·· Assuming the Stamp Module wasn't damaged by this, you can try manually cutting the trace on the top layer of the board (your board)·carefully with an exacto knife.· This should work.· Let us know what happens.
Chris Savage
Jon Williams
Dallas, TX· USA
Chris Savage
Don
