triggering multiple devices in sequence
i'm searching for a way to trigger up to 100·1.5V devices·in·sequence.
can someone suggest an economical way to achieve this without cascading basic stamps? and direct me to a diagram?
thanks
thanks
Do you want to ground them?
What is the maximum time you can allow between number one being triggered and number 100 being triggered?
Are these LEDs?
k
they are·strobe flash·units
and i'm looking for aprox .25 sec delay
How much current will you have to provide to switch the strobe units? If it's 125 mA or less, I probably have an answer for you.
If you can't answer the question about current requirements, a link to the particular strobe unit would be most helpful.
Bruce Bates
my response was in correct before- the ideal delay between the individual devices switching is something like .15 sec : 15 sec overall for the unit. but obviously it'd be nice to adjust the timing once assembled.
thanks
Do these need a charge time prior to triggering? Like the one's where you switch on the flash and you see a little LED be red then turn green and sometimes there a whining noise?
What is the charging time? (rough estimate is fine)
What is the current triggering mechanism? Is it a button? Have you seen if there is any means for aceesing that signal by soldering a wire into the circuit?
What is the furthest physical distance between any two units?
Post Edited (Paul Baker) : 4/24/2005 10:55:33 PM GMT
yes there is a capacitor which loads for for probably 2 seconds before the flash is ready to fire
yes i have inserted wires into the mechanism, which couls be connected to relays/ stamps.
furthest physical distance is 4"
If you need random access to your strobes let me know and Ill explain that solution, it basically requires 3:8 decoders but it requires a litle extra glue logic.
Since your flashes are so close to each other, I would run them off the same supply, because you will need a common ground between all your flashes and the stamp.
excuse my uncertainty, but this is all pretty new to me.....
so i'd attach the first serial shift register to a basic stamp [noparse][[/noparse]using two pins], and then cascade off the Q7 pin as you mentioned. all grounds would return to the basic stamp.
from each serial pin register pin i assume that i need to insert a relay in order to switch the flash circuits?
then the basic stamp code will direct the sequence [noparse][[/noparse]linear] plus timing. can you direct me to specific commands / or a tutorial that'll send me in the right direction?
thanks
____ __|_|_|_|_|_|_|_|_ | __|_|_|_|_|_|_|_|_ Stamp I/O pin 1 ----|DI | --|DI | | | | | pin 2 ----|> CK | --|> CK | | ------------------ | ------------------- +----------------------+for the first iteration make pin 1 high, toggle pin 2 high then low again the output is: 10000000 00000000
second iteration make 1 low, cycle pin 2 again, output is: 01000000 00000000
repeat the previous step and the 1 in the output will continue to slide down the column, you would do this until the entire sequence has been done.
You can use any stamp I/O pins, I only used 1 and 2 for illustration puposes.
if you do get a chance to expand it further, would be much appreciated.
I assume DI: is data input, CK: clock pulse
How does the shift register know to forward the information for the second sequence thru the 7 pin? is the space between the numbers the syntax to achieve this?
You are correct with the meaning of DI and CK.
The vertical lines ontop of the shift registers are the 8 bits of output with the left most one being the first shift position, the last shift position (I believe its called Q7 in the spec sheet) is connected to the input of the next shift register, that way the last shift position of the previous shift register is carried through to the next stage, ive highlighted the line im talking about below in red.
[size=2][code] Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q Q 0 1 2 3 4 5 6 7[color=red]____ [color=black]0[/color] [color=black]1 2 3 4 5 6 7[/color]____ [color=black]0 1 2 3 4 5 6 7[/color] [/color] __|_|_|_|_|_|_|_[color=red]|[/color]_ [color=red]|[/color] __|_|_|_|_|_|_|_[color=#ff0000]|[/color]_ [color=red]|[/color] __|_|_|_|_|_|_|_|_ Stamp I/O pin 1 ----|DI | [color=red]--[/color]|DI | [color=red]--[/color]|DI | | 74HCT164 | | 74HCT164 | | 74HCT164 | pin 2 ----|> CK | --|> CK | --|> CK | | ------------------ | ------------------- | ------------------- +----------------------+----------------------+[/code][/size]
Since the shift register places whatever is @ DI onto Q0 when CK is cycled, you are effectively creating a very long shift register (the above "super" shift register is 24 bits long), by chaining 13 together you get one really long shift register which has 104 bits (the last 4 are left disconnected and you basically ignore the fact they are there).
so, to the basic stamp code, which commands do i need to utilize to get this thing going?
also, each shift register pin will then get a charge [noparse][[/noparse]in sequence] , which i assume i need to attach a relay to switch the circuit.
(CK and Dout are defined to the respective pins)
CK = 0
Dout = 1
CK = 1············ 'first flash is now triggered (data is shifted on rising edge of CK)
Dout = 0········· 'since only one flash is active at any time the rest of the data shifted is 0
FOR I = 0 TO 98
· CK = 0
· PAUSE Delay·· 'this is the delay time between flashes
· CK = 1·········· 'next flash is triggered
NEXT
You would need something to drive the trigger like a relay, but I would suggest using a transistor since they are easier to drive (relays would likely need a transitor to drive them anyways). If you want to keep all the units electrically isolated then use a relay and ignore the part about connecting the grounds below (but connecting them together with some wire will be much cheaper than purchasing 100 relays)
The supply to each of the flash units would be powered up to·allow the capacitor enough time to charge, then triggered·by the pulse·from the shift register when the 1 is shifted to it's location. If you are going to have individual power supplies for each unit, you should tie all of the ground terminals together with each other and the stamp's ground.
Post Edited (Paul Baker) : 4/29/2005 7:59:16 PM GMT
