Performance profiling
Hi, we are trying to monitor 2 wheel encoder pins and drive motors based on that. This means that we need to have a fairly tight timing loop so as to not miss transitions.
My question is this: is there any timing information on the various instructions for BS2? Are bit-wise operations faster than integer operations? How about if-then? Is there any way to optimize the code for faster performance?
Any help that you can give us would be appreciated!
-Kal.
p.s. I did see the other posting regarding using an external counter to relieve the real-time need, but that is not an option at this time due to time and budget constraints in getting this project done! Next time, that sounds like the better plan!
-Kal.
You will propably find this information to be most helpful:
http://www.emesystems.com/BS2speed.htm
Thanks go to Dr. Tracy Allen, a regular member of this forum.
Bruce Bates
Looks like the instructions profiled are pre-2.5. I wonder if he will update with 2.5 instructions. In any case, it gives me a pretty good idea as to what is going on!
-Kal.
PBASIC 2.5 really does not change anything on the BASIC Stamp, so the timings are the same. The fancy stuff in PBASIC 2.5 is done in the IDE, and the IDE translates the new structures like DO-LOOP and SELECT-CASE into the same old tokens used by the BASIC Stamp from the beginning. The IDE is doing a lot under the hood to implement those higher structures. If you want to optimize for speed, you should understand how it does that translation. I have a page on that too, at www.emesystems.com/BS2pbasic25.htm. You can often optimize the speed of a loop by recoding it strictly in the PBASIC 2.0 syntax.
The speed of instructions on the Stamp depends mostly on how many bits of data have to be read from the EEPROM before the program can actually execute the instruction. For that reason, operations on bit variable s often take longer than operations on word variables. That might seem counterintuitive, until you consider that the address for a bit (with 128 possibilites) has to be longer than the address for a word variable (with only 16 possible addresses). Even within that there are tricks. For example, the IDE stores addresses and numbers that are powers of 2 in an especially compact form in the EEPROM, and as a consequence it can read them out faster. For example, it can address pin p8 faster than it can address pin p15. It can access the constant 2048 faster than it can access the constant 2047.
There are of couse some truly new hardware instructions (like I2C....) that first appeared in the more recent Stamps.
Tracy Allen
www.emesystems.com
Another pointer to a URL, which uses a state machine to scan multiple encoders with about the same time overhead as it takes to scan one:
www.emesys.com/BS2fsm.htm#twobit
It does have strong limits in terms o speed. It was okay when I wrote the code for beaded cable water depth gages in an application with a calibrated flume. The water depth never changed that fast. But with a motor, unless it is geared way down, it might overrun the Stamps' interpreter. Encoder algorithms have to catch each and every state, so the Stamp is limited to 100 Hertz or so, maybe 300 if you use the fastest Stamp, the new 'px.
The algorithm is simple boolean logic, so it can be programmed directly into an SX chip in assembly or with SX/B and then track multiplle encoders with time to spare.
Tracy Allen
www.emesystems.com
We are not using quadrature encoders (direction is deterministic), but we do have an additional complication in that we wait for 2 consecutive 0's or 1's before declaring a transition (debounce). Is that overly conservative? Do most people just use a single transition and have no problems with it? If we can get away with a single transition, clearly the loop can be a lot tighter. Any insights?
Thanks for the VERY informative web site, and answers on this forum!
-Kal.
Maybe you can just try your code without debounce logic and see how it goes?
Harry
So Harry has a good suggestion -- try it without debounce logic and see what happens.
Even with a bouncy switch, there is also the option of debouncing in hardware with an RC circuit, or with a key debounce chip like the MAX6817. That way your program doesn't have to deal with it.
If you know the debounce algorithm it is not hard to think of specific input trains that would fool it. But usually the probablilty of the bogus pulse train is low. The more samples, the lower the chance of error. For example, the MAX6817 samples many times during a 50 millisecond debounce interval, or, you could set an RC circuit to the same interval--An RC circuit with asymmetrical drive is like continuous time sampling. It would have to be an extremely bad mechanical switch to bounce for that long.
The bounce interval for a reed switch, is usually finished in well under 1 millisecond. If the reed switch is in an anemometer, for example, it may need to respond to frequencies of 60 hz or more in a high wind, so a debounce interval of 5 or 10 milliseconds would be the maximum without defeating the purpose.
Tracy Allen
www.emesystems.com
-Kal.
