3 different ways for diagram
Hi All..
I have attached 3 images of diagrams. Fig. 1 is from the MAX7219 doc., fig. 2 is from Jon Williams' tutorial and fig. 3 is from Steve Edwards tut. So I do not know which one I should or should have used. I wired it up following fig. 3 with one section and used Jon's code from his tut and the leds seemed to work except for all of them being lit while the code passed thru the leds. I decided that I needed to cascade them with the diagram from Max7219 docs and that is where I am at now. I have 4 of the 7 sections wired up and using Jons' code, it will not run the code thru the leds while they are powered up. Looking thru the max docs, it says to use a serial connection to set up the max7219 chips for cascading them.·I have wired· a test board but doesn't seem to be reading or doing anything with the chips. I had an old printer cable, cut off the useles end, traced all the pins to their colored wires to make sure I had the right numbers but still nothing. Maybe someone has some tips on using the max software for setting up the chips.
Is their a way to use the BS2 to access the chips to set them up in series? Or do I need to use my test board to set something up?
Sorry to ramble on but I haven't had the time to get this thing done. My wife and I are in the process of adopting a child from Russia and should be going there mid May hopefully.
Thanks again...
Jeff
Post Edited (slotcarz) : 5/3/2005 2:52:38 AM GMT
Thanks again...
Jeff
·· One connection is for 7-segment displays, the other is for matrix display.· What is the application you are using this in?· That might help determine the connections, since up to 8 7-segment displays can be connected to one MAX7219 chip.· Why would you need to cascade them?
Chris Savage
Parallax Tech Support
csavage@parallax.com
http://forums.parallax.com/showthread.php?p=533016·- project in motion.
The max will run up to 64 seperate leds. To keep wiring as simple and clean as possible I created a bank of leds at 8 columns by 7 rows, 56 leds. I assumed that I needed a 7219 for each bank of leds. It eneded up being 6 banks of 56 plus a 7th at 14 leds.
Hope I'm not confusing you as I am confusing myself
I would think that I created a matrix and would follow the matrix one as Jon has. I understood it as daisy chaining (cascading) the chips to allow the flow of data thru all the leds via the chips.
ok brain cramp... I gotta start dinner ... be back in a bit..
thanks
Jeff
Jon Williams
Dallas, TX· USA
·· Starting a new thread did confuse me.· If you're running more than 64 LEDs, you will need to cascade (Daisy Chain) MAX7219s.
Chris Savage
thanks for the replies...
Jeff
Post Edited (slotcarz) : 5/3/2005 2:55:18 AM GMT
