Motor Control: 2 Independent DC Servos
I'm working on a project that will use 2 independent motors with wheels attached, that will drive in a straight line.· I don't need to make any turns or go in reverse.· I just need to be able to control the speed of each motor, so that the unit goes straight for at least 20+ feet.· I've read my manuals that came with the "What's a Microcontroller?" and "Industrial Control" kits, but wanted to get opinions from more experienced enthusiasts.
I'm assuming that I would need something besides a 3904 to drive the motor?· I have a 12VDC - 18Ah battery that I can use to drive the motors.·
I've done some searching in the forums, but didn't find the answers I'm looking for.· Thanks for your time and help.·
Vmax = 44VDC
Imax = 5.7A (no RPM)
Imin = 100mA (6167 RPM, no load)
Thanks again,
Would it make sense to set a reference RPM on one of the motors and then take measurements on the second motor.· The only problem I see with this is if the load changes on the reference motor, it will get out of wack.·
Thanks again for your time.
You describe the motor as a "bushed sero motor", now, is this an actual servo (are there three wires?) or is this a regular motor whose intended use is in a servo (are there two wires?).
Thanks again for your time and help! [noparse]:)[/noparse]
Its late and Im tired, if any of this is unclear let me know and Ill try to clarify after I wake up.
