need help with MAX7219
HI everybody,
I'm experimenting with the MAX7219 seven segment display driver,
and i am using the MAX7219.bs2 file (that you can find in attachment) for trying, but i cannot resolve to ligth the decimal point.
has anyone suggestion to give me.
Thanks in advance
Thanks in advance
·· I can help you with the MAX7219 as I have used it extensively.· Basically to enable the Decimal Point on a given digit, whatever·hex value you are sending to a given digit must be logically ORed with the Decimal Point constant.· For example:
·· The variable d7219 is being assigned whatever is in the variable Value.· Let's say it's $00.· In the next line this is ORed with the value of DecPnt, which earlier was defined as a constant of %10000000.· What this is essentially doing is setting BIT7 of the value being sent to the MAX7219.· If you have any other questions, let me know.
BTW, this is for the Decode Mode.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Post Edited (Chris Savage (Parallax)) : 4/24/2005 3:44:17 PM GMT
during the initialization the decimal point of all the digits ligth on correctly so i know the wiring is done correct.
WHERE DO I FAIL?
·· It may be your code.· I don't know where you got the code, but you could try using the code from the StampWorks manual.· It's a free download in PDF format from our website, and contains similar routines to what I am using.· More importantly, it has the constants defined, and shows an example of using the Decimal Point.· The link to it is provided below.
http://www.parallax.com/detail.asp?product_id=27220
·· You can download it from this page.· I have a project in the works which uses the MAX7219 and in fact uses the Decimal Points in a very unconventional way.· However, the code is easy to follow.· When I am finished it will be posted in the Projects forum and you can download it.· Meanwhile try the StampWorks code.· I can answer questions on that code.
Chris Savage
thanks for the help that you are giving to me really in real time.
I'm attaching the MAX7219.bs2 file that i modified for the decimal point.
·· I will look over your code today, but in the meantime, try the other.
Chris Savage
i'm already having a look to the code you told me, and does not seem to me to have any difference with what i did on my code.
hope you'll find uot the busillis
regards
At the end i managed to get the decimal point work,
I simply defined a nibble for transmitting the number to display, and in that case there was no room for the decimal point information.
Anyway thanks for you advice
GREAT SERVICE
·· Ah yes, that would certainly hinder setting BIT7!· LOL· No BIT7 on a Nibble.· But at least you figured out what you were doing wrong.· That's great!· Take care!
Chris Savage
