Advice on hacking a power supply
I have an LCD screen that needs -22V, the flyback DC convertor I assembled doesn't work and I dont have the equipment and knowledge to·fix it (I will do a perfboard assembly of the circuit in case parasitics are affecting its operation). But I am considering trying to use an off the shelf supply and modify it to my needs so I can continue working on it. Allelectronics has a switched supply that has 5V, -48V and 48V. I am thinking of using a -24V regulator but most have a minimum voltage greater than -48V. So im thinking of using some rectifiers to drop the initial voltage, then a couple more to drop the final voltage to -22V. What are peoples thoughts on this?
-48V -|<|-|<|...[noparse][[/noparse]-24V Reg]-|<|-<|- -22V
Post Edited (Paul Baker) : 4/17/2005 10:10:39 PM GMT
http://www.farnell.com/datasheets/191.pdf is a nicely isolated little unit, that I've used for exactly this.
(edited to point at the dual output version - oops)
Steve
Post Edited (SteveW) : 4/17/2005 10:33:17 PM GMT
Steve
·· How much current do you need?· If it's less than 1A, you could use a standard transformer, bridge rectifier, filter caps, and a -24 volts regulator (7924).· This is of course, if the thing will handle the extra 2 volts, if not add your diodes...Think that will work?
Chris Savage
Parallax Tech Support
csavage@parallax.com
Also what is the rule of thumb for correlation between the AC RMS voltage and the rectified and filtered DC voltage?
·· One final thought on your project...What about a DC-DC converter designed for that voltage?· That is a small package and can handle a reasonable voltage.· As for your other question, if this is what you're looking for, the voltage after rectification and filtering is around 1.4 times the·RMS voltage.· If memory serves (It IS Monday!).
Chris Savage
(That Farnell part I suggested will do exactly what you want, for less than $10, straight out of the box. How hard do you want to make your life?)
Steve
·- 12V + - 12 V + - 5V +
························· Ground
Post Edited (Paul Baker) : 4/18/2005 5:25:33 PM GMT
What are you running the CPU from?
(In general, for stuff like this, I'll try to use a single rail supply, and generate everything I want locally - it saves conectors, switches, and hassle, and lets me sequence power supplies the way I want, if I need to. (If you look at your LCD data sheet, it almost certainly requires a careful power supply sequencing, with the -22V only applied when all the other supplies are stable and the data is streaming properly, or you'll risk damage)
The 5V -> -24V DC-DC makes this easy, because it's isolated. It's easy to wire it's +5V input pin to +5V, and ground it's 0V input with a small FET switch to turn it on when appropriate. (It's easier to switch a ground rail than a +vV Rail...)
Steve
