I'm using a DS1302 real time clock for a project. The clock is set in hex values I believe, I'm using a DEC variable x to set time, how do i convert this to a HEX to then output it to the 1302. Thanks
It doesnt really matter how you represent it in high level code.
In this·clock code the register addresses are represented in binary(%00010), the control register commands in Hex($80) and the data in decimal (12). It all gets converted to binary. Basically you can send it decimal numbers no problem.
' {$STAMP BS2sx}
' {$PBASIC 2.5}
'* DS1302 RTC
' I/O Definitions
Clk PIN 0
Dta PIN 1
RTCReset PIN 2
DIRS = %0000000000111111
OUTS = %0000000000000000
' Constants
CoreBank CON 0 'Program Banks
ClockBank CON 2
TskResetRCT CON 0 'Program Tasks
TskReadRTCBurst CON 1
YskWriteRTC CON 2
TskReadRTCRAM CON 3
TskWriteRTCRAM CON 4
SecReg CON %00000 'Register Adresses
MinReg CON %00001
HrsReg CON %00010
DayReg CON %00011
MonReg CON %00100
YrReg CON %00110
CtrlReg CON %00111
BurstReg CON %11111
' Variables
Task VAR Nib 'Current Task
RTCCmd VAR Byte
Temp VAR Byte
Seconds VAR Byte
Minutes VAR Byte
Hours VAR Byte
Day VAR Byte
Month VAR Byte
Year VAR Byte
TaskManager:
GET ClockBank, Task
BRANCH Task, [noparse][[/noparse]ResetRTC, ReadRTCBurst, WriteRTC, ReadRTCRAM, WriteRTCRAM]
[color=red]ResetRTC: 'Set Time and date to RTC[/color]
GET 10,Seconds,Minutes,Hours,Day,Month,Year
Temp = [b]$10[/b] ' Clear Write Protect bit in control register
RTCCmd = CtrlReg
GOSUB WriteRTC
Temp = Year 'Set Year
RTCCmd = YrReg
GOSUB WriteRTC
Temp = Month 'Set Month
RTCCmd = MonReg
GOSUB WriteRTC
Temp = Day 'Set Day
RTCCmd = DayReg
GOSUB WriteRTC
Temp = Hours 'Set Hours
RTCCmd = HrsReg
GOSUB WriteRTC
Temp = Minutes 'Set Minutes
RTCCmd = MinReg
GOSUB WriteRTC
Temp = Seconds'Set Seconds
RTCCmd = SecReg
GOSUB WriteRTC
Temp = [b]$80[/b] 'Set Write Protect bit in control register
RTCCmd = CtrlReg
GOSUB WriteRTC
GOSUB Done
ReadRTCBurst:
'Read From RTC
HIGH RTCReset
SHIFTOUT DTA, Clk, LSBFIRST, [noparse][[/noparse]%1\1,BurstReg\5,%10\2]
SHIFTIN DTA, Clk, LSBPRE, [noparse][[/noparse]Seconds,Minutes,Hours,Day,Month,Year,Year]
LOW RTCReset
PUT 10, Seconds, Minutes, Hours, Day, Month, Year
GOSUB Done
WriteRTC:
'Write to DS1202 RTC
HIGH RTCReset
SHIFTOUT Dta, Clk, LSBFIRST, [noparse][[/noparse]%0\1,RTCCmd\5,%10\2,Temp]
LOW RTCReset
RETURN
ReadRTCRAM:
'Read from RTC RAM
HIGH RTCReset
SHIFTOUT DTA, Clk, LSBFIRST, [noparse][[/noparse]%1\1,RTCCmd\5,%11\2]
SHIFTIN DTA, Clk, LSBPRE, [noparse][[/noparse]Temp]
LOW RTCReset
GOSUB Done
WriteRTCRAM:
'Write to RTC RAM
HIGH RTCReset
SHIFTOUT Dta, Clk, LSBFIRST, [noparse][[/noparse]%0\1,RTCCmd\5,%11\2,Temp]
LOW RTCReset
GOSUB Done
Done:
RUN CoreBank
Ok, now that I've got the setting of the time working, why does minutes 59 roll over to 68 (instead of increasing the hour by 1 and going to minutes 00).
Code:
setting:
number=-1
y=-1
GOSUB inbutton
SEROUT 0, BAUDRATE, 1, [noparse][[/noparse]"?f"]
SELECT number
CASE =1
x=x+1
CASE =2
x=x-1
CASE =3
y=0
ENDSELECT
SEROUT 0, BAUDRATE, 1, [noparse][[/noparse]DEC x]
PAUSE 100
IF y<>0 THEN setting
RETURN
Thank you JonB and Jon Williams, I was able to use Williams' dec to bcd to solve my problem, and JonB's information to solve some of my other issues.
An interesting note, all posters in this thread have the name Jon (I'm Jon Gowa).
·· In case you need it, I also recently posted some very easy to use code for accessing the DS1302, including the on-board RAM.· The code handles 12 and 24 hour modes very easily as well.· You can find it here:
Post Edited (Jonb) : 4/17/2005 7:00:40 AM GMT
· bcdVal = (decVal / 10 << 4) + (decVal // 10)
You can go the other direction too:
· decVal = (bcdVal.NIB1 * 10) + bcdVal.NIB0
Jon Williams
Dallas, TX· USA
Code:
setting:
number=-1
y=-1
GOSUB inbutton
SELECT number
CASE =1
x=x+1
CASE =2
x=x-1
CASE =3
y=0
ENDSELECT
PAUSE 100
RETURN
set:
Temp = $10
RTCCmd = CtrlReg
GOSUB WriteRTC
Temp = 98
RTCCmd = YrReg
GOSUB WriteRTC
Temp = $08
RTCCmd = MonReg
GOSUB WriteRTC
Temp = $27
RTCCmd = DateReg
GOSUB WriteRTC
GOSUB setting
Temp = x
RTCCmd = HrsReg
GOSUB WriteRTC
x=0
GOSUB setting
Temp = x
RTCCmd = MinReg
GOSUB WriteRTC
Temp = $00
RTCCmd = SecReg
GOSUB WriteRTC
Temp = $80
RTCCmd = CtrlReg
GOSUB WriteRTC
readtime:
GOSUB ReadRTCBurst
SEROUT 0, BAUDRATE, 1, [noparse][[/noparse]DEC Hours,":",DEC Minutes,":",DEC Seconds.HIGHNIB,DEC Seconds.LOWNIB," ",DEC Month.HIGHNIB,DEC Month.LOWNIB,"/",DEC Date.HIGHNIB, DEC Date.LOWNIB,"/",DEC Year.HIGHNIB, DEC Year.LOWNIB]
PAUSE 80
GOTO readtime
WriteRTCRAM:
HIGH RTCReset
LOW RTCReset
RETURN
WriteRTC:
HIGH RTCReset
LOW RTCReset
RETURN
ReadRTCBurst:
HIGH RTCReset
SHIFTOUT DTA, Clk, LSBFIRST, [noparse][[/noparse]%1\1,BrstReg\5,%10\2]
SHIFTIN DTA, Clk, LSBPRE, [noparse][[/noparse]Seconds,Minutes,Hours,Date,Month,Year,Year]
LOW RTCReset
RETURN
ReadRTCRAM:
HIGH RTCReset
LOW RTCReset
RETURN
http://forums.parallax.com/showthread.php?p=531080
Chris Savage
Parallax Tech Support
csavage@parallax.com
