Will the Futaba S5301 Hi-Torque 1/4" Scale (291oz/in on 6V) work with the STAMP.· I'm a little confused because the servo is not listed under "Digital".· Thanks.
An R/C servo need not be digital for use with the Stamp. In fact, most R/C servos used with Stamps aren't digital. A non-digital servo just uses pulses (PULSOUT) to control the motion. So, there should be no problem using it.
Bruce Bates
