Help! My infrared light meter needs a home!
Hey folks/tech support, I have what appears to be a simple issue I need some help on, please.
I have a breadboard infrared light meter. I wish to hook it up to my Basic Stamp 2 and record the voltage outputs over time on my PC. Of course, I will build the circuit on the Stamp breadboard.
The circuit designer advised me to "Connect the + of the output to the + input of the PIC. Connect the shield output of the circuit to the - input of the PIC. To the PIC the signal will start at zero volts and increase with light intensity." - a quote.
My (+) output is from PIN 6 of my L411 Op-Amp.
My negative is a lead from the shield circuit he has just described at a regulated 2.5 V.
1. To what part of my Stamp do I connect each?
2. What program can I use to record the voltages? ( I assume that Stamp Lite will only work with phototransistors).
Mr.Tbag
Post Edited (Tbag) : 4/15/2005 6:13:18 PM GMT
Mr.Tbag
Sid Weaver
NEW! 4 MB EEPROM
http://hometown.aol.com/newzed/page4.html
If so, can you tell walk me through the connection between my circuit and the ADC and the ADC and the Stamp 2? The ADC 0831 is ubiquitous I think, but I can post/send the specs with PIN numbers if this can help you.
Thanks very much
Mr.Tbag
Part 2 - what would be your personal preference if you were making an IR light meter - a photodiode or a phototransistor?
Posts very much appreciated
Tbag
