Oscope / Understanding Signals: Why does speaker stop functioning when cap is a
John Kauffman
Understanding Signals - Chapter 3 - Activity #1
page 36·in text version 1.0
I'm using homework board and leaving off the breadboard·the 220 resistor
Without the 1 uF cap in the circuit:
- tone from speaker is heard (although very soft)
- observe nice image of rough wave on Oscope
When 1 uF cap is added:
- tone stops from speaker
-·observe nice smooth sine wave on Oscop
Why does speaker stop functioning when cap is added?
2) Check the frequency of the sine wave signal on your oscilloscope.· Is it the 200 Hz that it should to be?
Nate
Larry
The wave on the Oscope is a perfect 200 Hz.
Based on Larry's reply, if the cap absorbs so much energy that the piezo speaker can not be powered, then I should expect no sound with the cap. Right?
So one of two situations:
I'm still doing something wrong and should be able to hear sound with the cap
- or -
Understanding signals should be revised to note that the two listening steps (p.36 third bullet and p.40 last line) should be done with the cap removed.
