Absolute MAX Voltage for BOE-Bot — Parallax Forums
Robert HodgenRobert Hodgen Posts: 8
edited 2005-04-13 14:28 in Robotics
I know that on the BOE it says 9-6VDC, but I was wondering what the absolute maximum voltage I could supply the BOE-Bot before it fried. I would like to know so I can find another battery pack for a project I'm working on. There are some high capicity RC car batties out there (7.2V 2000mAH and another pack at 9.6V with 1600mAH). I also noticed that the BOE-Bot seems to reset when the voltage drops, exactly what point does it do that at? Would a 9.6V battery fry the BOE and BS2?
    edited 2005-04-07 03:31
    Robert,
    ·· Your question depends on how the servos are powered.· If the servos are powered from Vdd, you can safely run 12V into the on-board regulator.· If the servos are being powered from Vin, you shouldn't exceed the 6 volts that the battery pack supplies, as it will wear out and/or damage·the servos.
    ·· As for brownout, that happens at around 4.3 volts.· But the stamp may not come back until 4.6 volts is reached.· This can happen more frequently if you're using rechargeable batteries (Not recommended) because they run at a lower voltage than alkaline batteries.··As for your 9.6V battery pack, use the BOE on-board voltage regulator and you should be fine.
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
  • Robert HodgenRobert Hodgen Posts: 8
    edited 2005-04-07 13:01
    Thanks Chris
    I have it set to Vdd with a 9V powering it, but the BOE-Bot will burn through a brand new 9V in 30min (with the servos running ~ 90% of the time). Could there be something wrong with the voltage regulator on my BOE?
    I have the 2 servos that came with the BOE-Bot, the piezo-speaker that came with the BOE-Bot (but it only sound for a sec. when it resets) the Ping))), and 2 red LEDs (that came with the BOE-Bot with 220ohm resistor). Does reprogramming the BOE-Bot (I do about every min for fine tuning the program) take a lot of power from the 9V on the BOE-Bot? I can’t think of any other explanation for this excessive power draw.
    Robert
    edited 2005-04-07 14:49
    If you're putting more than 6v into your BOE-Bot power connector then you should absolutely be using 5v (regulated) for the servos. If you go much above 6v you will start to see a lot of draw, especially when you go too high and that acrid odor of burning electronics (from inside the servos)·starts to waft your way (ask me how I know about this...). Programming the BASIC Stamp does not increase power consumption -- in fact, the loads are released momentarily so the power should actually drop while the programming cycle is in progress.
    Jon Williams
    Dallas, TX· USA
  • allanlane5allanlane5 Posts: 3,815
    edited 2005-04-07 15:57
    It depends on how many servos you are running. A 9-volt battery doesn't actually have that much power in it -- not compared to 4 AA alkalines. Each servo takes around 100 mA when running -- so if you are running several servos, and you run from a 9-volt battery, and you supply them from Vdd, then yes, 30 minutes to run the 9-volt flat sounds about right. I would expect your regulator to get a little warm while doing this, but that's not a problem.
    That's why the BOEBot from Parallax uses 4 AA batteries to power its two running servos -- they last longer than a 9-volt would.
    What Jon is saying is that if you power your servo's directly from Vin at 9-volts (bypassing the regulator, in other words) then they tend to melt. Max voltage for a servo is about 7.5 volts -- really they expect 5 volts to 6 volts as their 'normal' operating range.
    edited 2005-04-07 18:47
    Robert Hodgen said...
    Thanks Chris
    Robert
    Robert,
    ·· Based on replies, as well as your original post, let's make sure we're on the same wavelength...Are you using the 9.6V pack you specified above, or a standard 9 Volt transistor battery?·· The 9V transistor battery will have insufficient current to power a BOE-Bot for any length of time, however the 9.6V R/C Battery Pack you were asking about should.
    ·· Now 2 factors can affect the performance of your batteries...One, how they're charged and discharged...And this includes charging them with the wrong type of charger (For example NiMH batteries in a NiCd charger).· the second factor is heat (Probably not a factor here).
    ·· Which battery are you having the problem with?· You've already established that you're using Vdd to poewr the servos.
    Chris Savage
    edited 2005-04-12 12:11
    I went with a 9.6V battery from Radio Shack (its RC car battery) going through a home-made voltage regulator (the reguator drops the voltage from 9.6V to +/- 7V, my regulator will handle 1Amp). My regulator will give out +/- 7V until the voltage drops below 7V (although I doubt that having a 1600mAH battery [noparse];)[/noparse] ).
    edited 2005-04-12 14:02
    Robert, are you saying that the BS2 and Servo's are burning through a 1600 mAH battery in 30 minutes!?! That's using 3 amps for 30 minutes, dude! That is a LOT of power.
    No, there is no way that should happen (unless you're using 30 servos). But perhaps you've now replaced a 9-volt transistor battery with the 9.6 volt RC car battery, so you have longer life now.
    When you say your regulator generates +/- 7 volts, is it REALLY generating -7 volts? I would assume not, since that's 14 volts total peak to peak, which is hard to get out of a 9-volt battery. So I assume then that your regulator gives you 7-volts from a 9.6 volt source. And the 7-volts then drives your servos.
    If all that is true, then you are overdriving your servo's slightly -- that's assuming the servos are rated 5 volts to 6 volts. The 7 volt overdrive shouldn't damage any of the electronics in the servo -- but it may reduce the life of the electric motor inside the servo. Only you can decide if this is a problem.
    If the servo's are in fact designed for use with 7.2 volt RC car batteries, then you are doing no damage at all, and in fact have quite a clever implementation.
    edited 2005-04-12 16:19
    ·· The other thing to consider here is that you're also driving 2 regulators.· Each regulator will eat up some power as well...I almost wonder if it wouldn't be a better idea to just let the BOE regulator handle the 9.6V and run the servos from Vdd.· This will only work on a Rev C BOE if you have the jumper set to Vdd.
    Chris Savage
    edited 2005-04-12 17:22
    Yes, but the 7-volt regulator lets him drive his servo's with a full 7 volts -- much more oomph than using +5 Vdd.
    He's going to be disappating power anyway -- it actually makes more sense to disappate (2-volts * <Servo_Current> + 4-volts * BS2_current) than to disappate 4-volts * (BS2 + Servo_Current).
    Since the Servo_Current is MUCH more than the BS2, his approach makes lots of sense -- basically wastes half the power of the 5-volt regulator by itself.
    edited 2005-04-12 17:25
    Allan,
    ·· The idea was to try and eliminate an unknown (The extra regulator) from the circuit to see what effect it has.· Yes he gets more voltage to the servos currently, but 7 volts is more than they are normally rated at anyway.· No harm in simply trying it to see how quickly the batteries fade in the suggested configuration.· With what's happening, they could even fade quicker for all we know.· He needs to isolate the problem.
    Chris Savage
    edited 2005-04-12 17:52
    Ah, but I assume that his 'fast battery kill' problem was associated with a 9-volt transistor battery. Now that he has a 9.6 volt RC car battery with 1600 mAHour of capacity, I really hope he doesn't have the same problem.
    So, what do you say Robert? The RC battery doesn't die as fast, surely?
    edited 2005-04-12 18:23
    ·· Perhaps I myself am missing some information...I had the impression that he was using a 9.6V battery all along and that it was not lasting very long.··Robert were you using a 9.6V at the start of this thread or a regular 9V transistor battery?
    Chris Savage
    edited 2005-04-13 10:49
    allanlane5 said...
    I was using a regular 9V battery like you could find anywere. The application I'm using the BOE-Bot for requires the servos to constantly move one way or another (chaning really fast).
    I switch to the 9.6V RC car battery and it hasn't quit on me yet (I'v been using it for 2 days off and on). Another reason why I went with my voltage regulator was I originally built it for use with a RC car battery, I just had to get it into the BOE (I think it was easier using my regulator than having to mess around with the battery leads).
    Robert,
    ·· So what you're saying is that the battery that was being depleted was a regular 9V battery?· Well most of us at Tech Support got the impression the 9.6V R/C Battery was dying prematurely.· Okay, we now see the light.
    Chris Savage
