Sx tech voltage regulator heat
I am using a Sx tech board and have a Comtech serial LCD with backlight connected in the normal way to VSS VDD and serial to Pin on the sx board.
when im testing the display it works fine .. but the heatsink on the tech board gets quite warm even HOT to the touch, is this normal . .or am i drawing too much current for my power supply ?
i have other LED and such connected to it .. but my project is not using them while im testing the LCD
what am i doing wrong in this case
thanks again.
thanks again.
·· How hot is the heatsink.· Can you hold your finger on it?· Do you know how much current the LCD draws with the backlight enabled?· Also, how much voltage is going into the Vin?
Chris Savage
Parallax Tech Support
csavage@parallax.com
·and the same project running on my BS2sx with same LCD same power supply, the heatsink doesnt get anywhere near this warm using the BOE
by the way i have the SXkey plugged in .. ,
the LCD specs i cant seem to find on the makers web site but ill keep looking
The power supply is a 300 ma 9v wall adaptor ..
Post Edited (duffling) : 4/12/2005 5:56:28 AM GMT
The LM2940CT(http://www.national.com/ds/LM/LM2940.pdf) has protection for thermal overload among other things.
Chris Savage
A useful simple little fact about sensing temperatures, is that your finger can *JUST* continuously hold on to 120F (about 50C); any higher, even a couple of degrees F, and you must let go after 5 to 10 seconds.
Cheers,
Peter (pjv)
