C2D2 (R2D2) body for a Boe-Bot
A plastic Foldger's coffee can and a plastic bowl are going together to make a body for the Boe-Bot.
Post Edited (Russ) : 4/8/2005 5:52:21 AM GMT
My Computer Specs
_______
"I had no professional training, I gave it my all, I have no regrets" -William Hung
_______
Ben Damon
And may God Bless America!
Jon Williams
Dallas, TX· USA
Does anyone know of a better way to paint or color the plastic containers? The spray paint scuffs off to easily.
Also, if you take a look in the hobby shops, they have those miniature tins with paint meant for plastic models.
good job!
daniel woolston
Teksystems Inc.
www.danwoolston.com
Polyethylene (HDPE, LDPE, or UHMW) is one of those plastics that is impossible (and I do mean impossible) to paint.· Many companies claim to·produce paint that adheres to PE.· I've tried many of them only to have them fail.· I have not tried the stuff recommended by Paul but I have my doubts.· The description claims to create a chemical bond.· The problem with PE is that it is a fully saturated polymer and there are no bonding sites on the molecule at all.
Sanding the surface helps but slight scuffs can still rub the paint off.· Also, variations in temperature will cause the PE to expand and contract and the paint just peels off on its own.· I have found that one of the few things that sticks to PE is masking tape that is left on for a few weeks.· Then it's really hard to get off unless you use a solvent.
Many other plastics are paintable, a few others are not.· A good test to check paintability is to see if a drop of solvent such as acetone or xylene attacks (melts) a test sample of the plastic.
Chris Isaacson
you could download some images of r2-d2 components and use those on the stickers.
just a thought....
daniel woolston
Teksystems Inc.
www.danwoolston.com
greetings from belgium
Nice project. The picture to me looks a little bit like a "Dalek" from the Dr. Who series. Put a couple of suction cup arms on the front and Voila!. Exterminate! Exterminate!!
Sofa
.....and if I recall correctly, the name "R2D2" was originally derived from the way film canisters are labelled and stands for "Reel 2, Day 2"...
Truly Understand the Fundamentals and the Path will be so much easier...
