Project - Machine to measure punching power
Hi there. I've been doing some research trying to come up with the best (and most economical) way to build a machine that measures the punching power of a boxer. What I want to do is have them hit a speedbag, and be able to get a numerical readout on a·4 digit LED·(the harder they hit the higher the number). This number by itself will have no meaning - it doesn't have to reflect pound force or anything like that - but will be accurate in relative terms to someone else hitting the speed bag. For example Mike hits the bag and gets a reading of 109, and then if Bill hits the bag 3 times as hard he should get a reading of 327. From asking around the best method I'm told would be to attach an accelerometer to the back of the speedbag (or insert it in the center) to measure the force of the punch. Once the bag is struck, I would like it to take a continuous sample over about a two second period and the number it ends up displaying would be an numerical interpretation of the peak·acceleration measured over that period. A second 4 digit led display would display the highest score to date. I have been searching the web exhaustively for a simple/cheap solution to this, and came across the·Basic Stamp 2. I don't have much experience with electronics, but have some programming background, and from what I've read so far·the learning curve is pretty gentle compared to some other solutions.
Would·the·Basic Stamp·be able to achieve what I am trying to accomplish?
Here is an example of what I am looking at doing (only mine would have a much more simplistic physical design):
http://www.coinopexpress.com/products/mach...rs%29_5932.html
Again, I am looking for simplest method possible for getting data from the accelerometer directly to a·microcontroller and being able to manipulate that data to output a numerical reading that displays relative punching power. Any advice would be appreciated.
Dennis
Dennis
how much force the bag was hit with a few calculations. There are several examples on how to interface an accelerometer to a stamp.
Beau Schwabe - Mask Designer III
National Semiconductor Corporation
Latest Company News
(Communication Interface Division)
500 Pinnacle Court, Suite 525
Mail Stop GA1
Norcross,GA 30071
http://www.coinopexpress.com/products/machines/sport_games/Boxer_Punch_Machine_(Plain_Colours)_5932.html
Having said that, when boxers punch hard, even if there is a lot of padding there's still some residual accelleration. Come to think of it, it is that residual accelleration applied to the other boxer's head that is the goal after all.
Conclusion -- yes, this approach may give you some useful numbers. Note the 'pulse' of accelleration may be quite short -- on the order of 10's of milliseconds. I would assume the goal is to apply as much force over as little time as possible. Force = Mass * Accelleration, so if you know the mass of the bag and can measure the accelleration you can get the force.
P.S. Yes, the BS2 can be used in these conditions.· It cycles fast enough and measures pulses as part of its native 'PBasic' language.
Post Edited (allanlane5) : 4/7/2005 6:36:14 PM GMT
I would think that the moment arm length or pendulum of the bag will also need to be taken into account with the mass
Latest Company News
Mail Stop GA1
Norcross,GA 30071
a shorter person with the same force hitting lower on the bag may make the bag move
differently than a taller person hitting higher on the bag ( bag hanging )
Comments?
So the weight of the bag plays a bit in this.
Someone like Mike Tyson who, doesn't just bite off your ear but, punches 'through' you wouldn't necessarily have a fast punch but would do more damage. Whereas a Sugar Ray Leonard or Billy "the kid" Irwin (canuck fave) would have a fast punch with less power but enough to move the bag and score points.
So, you might want to have a boxing game and then like a Home run derby (or a "knockout" derby) for the hardest punches.
I played a game similar to this a ways back....and there was a screen in front of you with a boxer dancing around. The idea was to hit him when he was vulnerable. The trick was to hit him hard and fast as soon as he became open, to score the most points.
You might want to use a reaction timer as well as a green light that's on for a certain amount of time. The faster they hit the bag when the light goes green...the more points they'd win.
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
A better solution will be to measure the velocity of the bag. This can be done attaching a solid link to the bag and attaching a pot to it on the other end, then we ad a pull down resistor and measure with the command "pulsin" the time which takes the bag to do the full arc.
Bean.
"SX-Video Display Module" Available Now.
www.sxvm.com
"A problem well defined, is a problem·half solved."
Post Edited (Bean) : 4/8/2005 12:45:35 AM GMT
I think they had an encoder attached to a level (of which you hit one end). The lever had a large coil/spring that would make it harder to push the further you got.
So, as the lever got hit it would obvious increase a POT or increment an encoder position.
This also allowed for the bigger slower guys to push in the the spring more and win more points....
You could have a slotted opto to measure speed (timed break of light beams)....and also have an encoder for the force....
Steve
As L_Gaminde, Beau, and allanlane5 pointed out, there are several variables that will come into play. And, unfortunately, they will all be working against you in trying to come up with a number that means "anything" in relative terms. If you imagine a really powerful hit striking somewhere near the top of the bag, and then imagine a somewhat softer blow impacting near the bottom of the bag, the physics of it may very well register a larger number for the second hit (assuming the bag was suspended from its top point, that is). This can be negated by having a very small target...and a heavier target would take care of some of it.
Ain't physics fun?
Truly Understand the Fundamentals and the Path will be so much easier...
if the bag had a differently colored area
that was the punching area and was able to
be moved up and down you could set up the bag
for anyone, you could also use this to show that
different punching hights relative to there waist or
sholders gives different punching power and could
use this to determine each persons sweet spot
I am slightly concerned with the idea of an accelerometer. Since this is a tightly teathered object, the window of accurate acceleration measurement will be quite small. To get an accurate reading you will have to do a multi-sample during this time window. Without going into the physics of determining what this time window would actually be, Im not sure if the stamp will be fast enough to get reliable readings with every punch.
Post Edited (Paul Baker) : 4/7/2005 8:57:59 PM GMT
as luck would have it, i am also in the early stages of a similar device for a martial arts instructor friend of mine.· after much hunting on the web a week or so ago·i came up with a product close to what i want, and i think exactly what you want:· http://www.imptec.co.uk/html/product-information.htm
and very good strikes will register over 2.00 Imptec units."
"The unit measures from 0.00 to a maximum of approx. 4.00 units in 400 measurement steps."
searching a martial arts forum bounced me to something that alluded that they use a simple accelerometer, +/- 10 g i believe.· the imptec·thing is their arbitraty impact unit that i feel is basically a slight of hand to avoid the mish mash of potential·issues with lever effects·as beau mentioned, deformations of the bag, mass of bag, contact time (long for a boxer, very short ~5 ms karate strike), etc.·thus boiling it down to simply a scaling of acceleration.· i personally wanted an actual·force·output as it seems more meaningful, but i dont think it is as simple as F=MA due to those issues, could be wrong though.
back to the stamp, i havent given it too much thought yet, but·i·suppose you could·continiously scan with·PULSIN to gather the·duty cycle from a +/- 10 g·accelerometer like the memsic MXD2002 or analog devices ADXL210E, if PULSIN returns a value > 0G (> 50% duty cycle) + threshold·there must have been a hit·that needs to be scaled to be output to an LCD/LED, ignore all < 50%·duty cycles·as that is the bag swinging back.··the threshold is a magnitude "lockout" to prevent registering "false hits" as·the bag oscillates back and forth.· quickly looking at the datasheets for those accelerometers, they·are good for·50,000 (MX) and 1000 (AD) g's of shock survival·and·are available·up to·10ms duty cycles which should be no problem for BS2(PULSIN res @ 2us)·to measure, process, and display prior to another strike???·
food for thought i hope, input/comment??·
ross
ps - another website i had found·showed various·applications·that their accelerometer was used for, one was to test·a 5x world karate champ, as i recall·he·kicked w/ ~2300 lb force and punched w/ ~1900 lb force!
Who is going to view the "punch stats"? The fighter, trainier or both?
As you mentioned, you are not interested in a "real" number, but at least something that is relative to the punching power.
Parallax sells the flexiforce pressure type sensors.
·http://www.parallax.com/detail.asp?product_id=30056
Can we assume the area of the glove that will strike the bag is relatively small....?
Maybe mount the flixeforce sensor in/on the glove itself and run wires to the monitor unit (could get messy though), or use an inexpensive RF unit to transmitt the data.
http://www.rentron.com/remote_control/TWS-434.htm
www.msiusa.com/piezo_documentation.htm
Tracy Allen
www.emesystems.com
You can put as much padding on the sensor as you want so it won't break anyone's hand.
Post Edited (StarMan) : 4/8/2005 6:04:43 AM GMT
I have to say I'm still quite the kid and love arcades! My first job out of college was in a "family entertainment center" (arcade! lol).
Part of the fun in playing these types of games is finding their "sweet spots"....this is what enables a little kid to beat a giant. If the kid accidentally hits the sweet spot while the big gorilla is pounding away with full force. I wouldn't worry too much about the imbalance in energy transfer from hitting the top of the pad or the bottom of the pad.
If you wanted to void that (sorta) then don't use a 'swinging' target...or a levered target. Use what equates to a piston. So that it's horzontal to the strike path....but I'd leave it so that there's some imbalance!
You all remember the Hercules hammer thing....hit the pad and it sends the weight flying up....and if you hit the bell you're hercules! Well, if you hit further out on the levered pad, then the energy transfer was greater and it went higher!
Steve
Check out a company called Pacific bearing for rods and bearings.· I believe Mc Master-Carr carries some of their stuff.
Steve
http://www.tekscan.com/flexiforce/specs_flexiforce.html
I would want to install this under the surface of the bag, so that would absorb some of the impact to the sensor, and because there is nothing behind the bag, and it moves freely with the punch that should help absorb any potential damage to the sensor.
Latest Company News
Mail Stop GA1
Norcross,GA 30071
Steve, you hit the nail on the... eh... you hit the bag on the sweet spot. I have worked for an arcade company for almost 20 years and "gorilla" is my usual terminology for the mighty force that is the idle young male who has so much energy he should be out ploughing a field with a collar around his neck or something.
Keep that in mind, bannor32, as you build. Our customers shake bolts loose (use Loc-Tite). They break welds (use an experienced welder). They kick cracks in particle board, tear tubular forms in half, bend steel reinforced steering wheels, unscrew knobs and take them for souvenirs. Do not underestimate the player... especially if he is half drunk, feels he has something to prove, and wishes to use your machine to do it.
Back to your engineering... the problem with a sensor in the bag is not the sensor itself but preventing the connections to it from being broken or becoming intermittent. For any mechanical game, shock and vibration will be your nemesis. Whatever you put in, make it as simple as possible. Do not allow wires to be stretched; make them long enough. Prevent wires from moving relative to the sensor, as they will simply snap off after a few flexes. Use finely stranded wire, which is less likely to break.
NOT to discourage you from your project... but the Boxer game is pretty well made as boxing games go. If you do buy a Boxer game, stroll out to the hardware store and buy a bottle of Loc-Tite(tm). You'll need it.
(Hint: ask for a local dealer at the manufacturer's site, www.jakar.pl)
