WHATS happening here? — Parallax Forums
dufflingduffling Posts: 73
edited 2005-04-07 15:58 in General Discussion
why does the LED turn off in debug mode .. yet not when i program the sx?
what am I doing wrong?
DEVICE DIRECTIVES
··DEVICE··SX28,OSC4MHZ,TURBO,STACKX,OPTIONX
········ IRC_CAL··IRC_SLOW
··FREQ ·50_000_000
··RESET··Initialize
VARIABLES
COUNT1 EQU $09
COUNT2 EQU $10
WATCH COUNT1,8,UDEC
INITIALIZATION ROUTINE
Initialize
··;Configure port settings
mov !rb,#%01111111··· ;SET RB.7 AS OUTPUT FOR LED
MAIN PROGRAM
MAIN
CLR COUNT1
CLR COUNT2
MOV RB,#%00000000
LOOP·················· ; SHORT DELAY
DJNZ COUNT1,LOOP
DJNZ COUNT2,LOOP
··· ; TURN OFF LED
MOV RB,#%10000000···
END
  • RsadeikaRsadeika Posts: 3,862
    edited 2005-04-06 12:20
    I had the same thing occuring to my little test program just the other day. Here are the assumptions that I made: In assembly, END is not a command; without specific code such as an endless loop, SLEEP, or a jmp $, the processor just keeps running the program over and over. So, the coomand you have at the end of your program to turn off the LED occurs so quickly, it looks like your LED never turns off. As a begginer this is what I think is occuring.
    edited 2005-04-06 16:22
    I can only confirm what Rsadeika mentioned: END simply signals the Assembler that no more program code to be handled by the assembler follows. IOW, you could place whatever kind of text in lines following the END, and the Assembler will ignore them. This sometimes is handy when you want to add some documentation to a source code file.
    When the SX executes the code, generated from your sample program, it will run into "nowhere land" after doing the MOV RB, #%10000000. This unprogrammed area of the program memory usually contains $FFF in each location.
    Just add
    jmp $
    following the
    MOV RB, #%10000000
    to bring the SX into an endless loop.
    Greetings from Germany,
    G
  • dufflingduffling Posts: 73
    edited 2005-04-06 17:53
    Ok . i follow that .. the jmp$ fixed the problem .. thanks for the help guys..
  • KenMKenM Posts: 657
    And just for your info, the command
    jmp $
    is a jump to the current program address, and that instruction is cryptic to some.
    The equivalent less cryptic command is:
    finish
    jmp finish
    And just at Guenther mentioned the program is in an endless loop to nowhere.
    K
