Self Charging Boe Bot
Is anyone working on this, or got it to work? I would love to see some examples because Im not sure how to attack this problem, reliably and simply.
Ray
Ray
·· Check out the "Robo-Cut" and the "OctoBot."· Both self-charging robots.· Both pretty popular.· You can find them via Google.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Technically, this would be self charging·...·
Ciao,
Mark
Small Solar panels doesn't deliver much power, I'm afraid.
Just take a look at the Mars Rover and similar solar powered projects.
Their entire top is covered in solar panels, of a better quality than you can expect to get hold of, the electronics is optimised for low-power, every mechanical component is made as light as possible...
If you want to have any hope of getting any power at all, you'll need to have the panels tilted to follow the sun perfectly.
If you really want to try, I suggest using a BS1 for this task as that's the Stamwh which draws the least power.
You'll need to carefully consider the motors you use to position the panels.
Do you want as small as possible, adding less weight and drawing less power , but is slower to adjust the panels, or
do you want bigger motors which draws more power and can adjust the panels quickly?
Will the bot be moving a lot?
Will it be going mostly straight, or turning a lot?
will it be operating on even ground, or bumpy roads?
There's a lot of questions to consider, and no easy answers.
(Of course, being Stampers, we don't DO the easy answers...
Hope I didn't scare you away...
Ray
·· Hence my previous reply...Both robots demonstrate that ability, and if you read up on them, perhaps you will get some ideas.
·· It seems the main thing is to be able to check your current power level of the batteries, and when they reach a certain threshold voltage, you need to start tracking a "beacon," which could be an IR LED.· This is something easy for a BOE-Bot to track and move toward.
·· Then you have the hurdle of a mechnical interlock which can easily charge the batteries while the BOE-Bot simply stops in front of it.· Both bots I mentioed above have accomplished this task quite effectively.· Good luck!
Chris Savage
Post Edited (Chris Savage (Parallax)) : 4/4/2005 1:31:20 AM GMT
Pump low voltage AC current through a coil on the base, then move the bot close enough to pick it up with a coil built into the bot.
Then it's just a question of feeding it through a rectifier and smooth it with a decent sized capacitor.
Hmm.. might raise havoc, putting a AC coil, under the servos, which both have perminant magnets in their drive motors.
Exposed connections, Also a bad idea.. but, millions of cordless & cellular phones have them too..
An alternative, would have to be some kind of targeting system, with a wide target. kind of like NASA uses for their
manned space missions, where the docking platform has a circled "+", the astronauts need to line-up on, to insure
a fit with the docking ports.
Hmm.. Cordless phones... That just gave me a brainstorm.. I had a cordless phone, which had perminant
magnets built into the contacts on the handset, and the pins on the charger/base were spring-loaded..
Idea: magnets behind the contacts of the BOE, and opposite pole magnets on the charger base contacts.
put the contacts for both inside some kind of shield, but leave just enough recess depth so the contacts will extend
when the magnets on the opposite (charger/BOE) make contact, But not too strong, that it makes it impossible
for the BOE to pull away (or pull the charger along with it.
example (in awful typed graphics) Bot: =[noparse][[/noparse] ]= :charger (away from eachother)
Bot: [noparse][[/noparse]==] :charger (when in contact)
Now, the fun part, telling the BOE when it's had enough to eat, and back away.
Stephen (gelfling6)
Bean.
"SX-Video Display Module" Available Now.
www.sxvm.com
"A problem well defined, is a problem·half solved."
lets say the bot reads the battery is low and goes from its autonomous roaming state to looking for food state. I wonder if I took the Tab Sumo Bot board and incorperated it into the charging station. Lets say the charging station becomes the beacon. Even if you couldn't get the boe to read its battery state maybe you could use the charging station as a clock say after the bot has left the station the charging stations waits, I don't know 45 minutes an hour then starts to flash a beacon for the bot. (like my Mom did when I was a kids, she'd turn on the porch light = time to come home)
now the bot has to hone in on the charging station. But what to use as the beacon. Photorestiors would be to weak IMHO...
I have a Tab Sumobot and a Boebot, I would like these to be the main componets of my little experment. I looked at the octabot and the robomower but they didn't really help.
It would seem I need to 1) monitor battery state or use a predetermined roaming time
2) find the charger
3) charge till the battery is full or charge a predetermined time
4) successfully leave the charge
again Im still just think about how, and thinking out loud and since you guys have some of the biggest brains I thought I would start by thinking and talking about it before I started blowing things up.
or as my wife says " your project is making that smell, you know THAT smell!"
FYI as I think about this more I wonder if the same principle as the Garage Sonic Range Parking Assistant http://forums.parallax.com/showthread.php?p=523373·, I wonder if the same principle could be applied, except the car would be the bot?
Ray
Post Edited (Ray Iddings) : 4/4/2005 3:47:57 AM GMT
·· Phototransistors could work.· But the best way to get rid of ambient interference is to use a modulated signal.· To that end you could use an IR detector just like those included with the BOE-Bot to search for a modulated (38khz) IR signal.
Chris Savage
The other major means is like what Chris mentioned, a homing beacon. This can be done either with RF or IR, but IR is cheaper and easier to manage by a stamp. The beacon would be several IR LEDs mounted axially like the spokes of a wheel and driven together. When the battery power drops it would switch from roam to seek, which is exactly the same as roaming except when it detects the beacon it uses that vector as its direction.
There is a potential problem with the IR beacon and that is if you are using IR as your object avoidance system, the beacon can blind your robot. A method around this is to create an intelligent beacon. When your bot is just roaming it just uses the IR carrier and looks for the reflection. When it is in seek mode, it will send out a modulated IR signal that you predetermine. When your beacon detects this special modulated IR signal, it will echo back a response and your bot will know the direction to the food bowl.
·· The only potential problem I can forsee with the Beacon being activated, is that the BOT would have to spin around several times sending out it's activation signal, while monitoring the see if this has occurred.· Not that big of a deal, but for some it might make things too complicated.
·· Another method might be to use a lower frequency modulation for the IR beacon altogether.· This would involve using a different receiver, but still pretty easy.· And finally, a radio signal could be emitted from the BOT to activate the IR Beacon...If it's not found within a few rotations, the BOT could re-transmit.
·· All are valid courses of action, and I guess the complexity is a matter of perspective.· I guess the best we can do is offer suggestions, and the OP can use one, some, all or none!·
Chris Savage
Tonight I will set up a Homebase and see if I can start to get the bot there, baby steps...I just thought when I asked this question someone else might have already blazed a trail.
Black is ground right??
Ray
Chris: optimal bot behavior when switching from roam to seek would likely cause the bot to spin around looking for the beacon to see if its visible from current position anyways. Then if no beacon is found, travel in a direction which there is no object avoidance IR reflection (meaning a clear pathway) travel a ways and repeat the spinning action. It seems this behaviour would be the same regardless if the becon is constant on or relay responsive.
················A very basic question, please forgive me, but how are you able to know that the boe-bot batteries are running low..I mean via the·Baisc Stamp...is there a·special function to do this?
Cheers
R.K.
Once you know that, you should be able to reliably measure the battery voltage, and know (from testing) how much longer you can use that battery.
And you measure the battery voltage using the RCTime command to charge and then measure the discharge time of·a capacitor I believe.· There's a few examples in the Nuts&Volts articles, I think.
the robotic vacumn cleaner. When its batteries are low it searches for an IR Beacon coming from its base.
Price $250
I'm gonna put together some pics of my disasters and my code (what a mess) and hopefully you guys can help me. Love the failures..hehe
Ray
