ds2408
does anyone have some code that will talk to a ds2408 ???
i would like an example of how to talk to a single ds2408 and how to talk to 2 ds2408's on the same 1-wire.
thanks
HardwareWizard
thanks
HardwareWizard
Jon Williams
Dallas, TX· USA
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/3818
So do a search for 1-wire... actually try a few different words, the forum search acts weird
Edit: After reading over the datasheet, this IC is terribly complicated to use. There are much simpler ICs on the market for expanding outputs or switching considerably more current if this is your goal... What is the intended application if I may ask?
As for talking to 2 of them, their 64bit address is·lazered onto the rom. The 1-wire protocol has provisions for selecting the IC using the distinct serial number. Other methods involve switching between different channels with an additional switch IC. I've never tried this so no details sorry.
Post Edited (Jonb) : 4/1/2005 4:57:38 AM GMT
Jon Williams
Dallas, TX· USA
I had the same issue with my DS2406, for a while. It seems that the 1-wire is not the most popular devices in this forum. I posted some code in Jan, which worked for a 2406. The 2408 is more complex but my feeling was that if 2406 can work then a 2408 should do as well, just more code.
Lars
(The Ds2480 takes TTL level Serial and converts it to 1-Wire protocol. Quite a nice chip, really)
The REALLY good ting with 1-Wire chips is just that; 1 wire, no matter how many chips you want to control.
As the chips have 64bit serial numbers, which can be easily read, they are very good for electronic locks.
Being able to address all of them at the same time, by using the SkipROM command, you can order all the similar chips to do the same operation, all at the same time.
(Like locking ALL your door-locks, starting temperature readings, or... )
Take a look at the different chips and you'll soon notice that special commands(like starting a conversion) all have unique Byte values, and that only the READ commands are the same.
(When a 1-wire chip receives a command it doesn't understand it will just be ignored)
Unfortunately, though, they are 'a bit' quirky to work with.
Jon Williams
Dallas, TX· USA
