All SX-Key Users - Request for Comment
At the risk of making my life miserable, I have decided to ask for some public comment on a proposed change to a specific SASM error message. Bean posted a message a few days about an error he got on the following code:
The error simply said: Missing label
I did a little research and discovered that "global" is a synonym for "equ" in SASM, hence he was writing the equivalent of:
So, while the error was factually correct, I feel that it is a bit terse for it's own good. As someone who likes to ramble on (right, Ken?), I decided that the error message might be better if it said this instead:
or for EQU:
My basic question is whether the existing error message is fine as it is. If not, is my proposed error message helpful or too verbose?
BTW, this is a proposed change. Don't get too upset if it doesn't make the final cut of work to accomplish. Also, please don't flame me with lots of "Don't fix that thing you dope! Fix this important one instead!" I'm working on lots of things, so don't assume I'm not working on your favorite problem/suggestion.
Global EQU 0x0C
equ equ 0x0c
GLOBAL must have a label in front of it, e.g. MyConst GLOBAL 15
or for EQU:
EQU must have a label in front of it, e.g. MyConst EQU 15
PeterM
Thats my $0.02.
Chris
·· The proposed message would be more intuitive.· I certainly can't picture anyone being against the change for any reason.
Chris Savage
Parallax Tech Support
csavage@parallax.com
I agree with Chris - the proposed messages are more intuitive.
IMO, such messages may explain the reason for the errors as clear as possible to give the user an idea what's wrong, instead of having him to read the docs for more information. IOW, it is fine with me when such messages are "verbose" as they normally should not show up anyway
Greetings from Germany,
G
Bean.
"SX-Video Display Module" Available Now.
www.sxvm.com
"A problem well defined, is a problem·half solved."
Perhaps you could add the fact that "global" is a synonym for "equ" to the next version of the SXKey manual. It is in the SASM help PDF, but I guess that's not the most popular place for people to look.
Thanks, PeterM
I have never seen one. Every program I have written is perfect the first time. (NOT TRUE, but you already knew that)
I have no objection to the proposed change.
ken
I know I can find the list of error codes in the SASM manual, but that doesn't help my poor feeble brain. I would love to have a list of what the error "really" means and possible solutions.
I suspect all good programers lapse into neglecting to really write precise, clear error messages. They are more concerned with making the system work and not produce these obscure errors.
In other words, Edit the error messages to be more self-explanitory. Or, eliminate GLOBAL. Or, both. Keep it simple. AND, KEEP IT COMPACT.
I really don't want another 1000 pages of pedantic documentation. And I am sure it will expand to 5000 before it is dropped.
This one would make it easy for me to move on:
ERROR 59: You are an idiot. This program is not for you.
I see your point - solution proposals would be nice. I am not sure that they would always be clear.
For instance,
I learned Eagle PCB software and I really cannot sort out all the error codes and their validity.
The board that I designed looks fine and prints fine, but the list of errors makes me feel very stupid.
I suppose as I really need to know, I will crack their code.
Sometimes the error codes are their to identify problems at a level that is quite obscure.
