BoeBot + BS2 + Parallax Servo controller
Hello
Till yesterday i used my boebot with continuos rotating servos connected directly to the I/O pins, now I have a PSC and need to know how to manage a continuos servo for a 360 degree rotation (I know how to do it with 180 degree). I try with no modified servos and works ok, but ..... Which command do I need to send my PSC to obtain a continuos rotating forward ??
What happens then is if you send a 1.5 mSec pulse (repeated every 20 mS, of course, standard Servo control signal) then the Servo stops. If you send a 1.7 to 2 mSec pulse, the servo spins one way -- and I believe it spins faster the further away you are from 1.5 mSec. If you send a 1 mSec to 1.4 mSec pulse, the servo spins the other way, again faster the further away you are from 1.5 mSec.
Thus you tell the PSC to send the above pulses to the 'modified' servo. Instead of going to one position and stopping, the 'modified' servo keeps spinning, until you send the command to send a 1.5 mSec pulse. Then it stops.
Post Edited (allanlane5) : 4/1/2005 6:14:56 PM GMT
You're right !! "...until you send the command to send a 1.5 mSec pulse. Then it stops". It works fine.
Well, it's time to build a wheelleg-bot. Take a look:
http://biorobots.cwru.edu/projects/whegs/whegs.html
Thank you.
