Scrolling LED "Medals" from Robolympics now available to SX programmers
Hey SXers:
We recently donated engineering·services to the 2005 Robolympics·(March 25-27th) by designing and manufacturing programmable awards for the 300+ robot contest winners. The awards·will be·customized on the spot with the winner's name and·the contest they won. Each PCB is surrounded by a medal "gear ring" so they can wear the award around their neck at the contest.
Once we got underway with the design and made a prototype, we decided these were simply cool as general-purpose display devices and for learning the SX with SX/B. Therfore, we ordered an extra 500 of them for our SX customers. We don't have much in the way of documentation, but we have sample SX/B code and a schematic, which should be enough to get the SXers on their way. David Winchell (from this forum) came to our office with the first prototype of this product in December and wrote the example code, so this was all his idea.
You can buy Robolympics Medals for $11.95 each. Details and on-line ordering are here:
http://www.parallax.com/detail.asp?product_id=28099
If the $6.00 shipping is too much for a single item, consider adding one of our new PING))) ultrasonic sensors to your order:
http://www.parallax.com/detail.asp?product_id=28015
These are really·popular sensors and I'm sure we're going to be back in a backorder situation·by next week (which could last up to·eight weeks).
Sincerely,
Sincerely,
(Out of horrified fascination, it that Protel PCB doing the layout?)
Steve
- Ken
David did a great job with the SX/B code too.
Bean.
Check out· the "SX-Video Display Module"
www.sxvm.com
Thank You
David Winchell
David@Winchell.com
Ryan
We have about 190 left. I'm not sure how long these will last. They could last six months or three days. Our distributor in Thailand is threatening to buy them all, but he has done that before. Therefore, [noparse][[/noparse]dare I say this] there's probably little rush and we'll still have quite a few in several weeks.
Ryan
No, the gear ring is not included. For interest, I have attached two pictures of the rings we made on our CNC. The first picture shows the ring being routed (prior to finish pass) on the table and the second picture shows two completed rings. The PCB medal fits tightly within the ring and it looks really neat. These take about 40 minutes to make on a CNC considering the movement of fixtures.
The Robolympics (Robogames) folks made their own style, which is torched-cut. It's also pretty neat, but not nearly as classy as the CNC aluminum rings that we made for the prototypes.
Ryan
I could send you the drawings, though. Send me your e-mail address to kgracey@parallax.com if you want the drawings. Maybe you have a friend who has a CNC or you could have them made at a local shop?
Thank You
David Winchell
David@Winchell.com
Bean,
Which clock would be be simpler to interface - the serial DS1302 or the I2C DS1307?
I thought of another good project, a display that changes to the music... Hmmm, exchange the speaker for a microphone...hack some circuitry on the back... I think it could be done.
Bean.
www.sxvm.com
"A problem well defined, is a problem·half solved."
I was thinking of using a microphone also - but for a different purpose. I figured the battery life on the unit (3 AA's running 105 LED's) wouldn't be very good so I thought of rigging up a simple sound detector that would automatically shut off the LED's if no sound was detected for xx minutes.
Bean.
www.sxvm.com
Bean.
www.sxvm.com
Ryan
Bean.
www.sxvm.com
Thank You
David Winchell
David@Winchell.com
·· When the batteries do die, it sounds kind of funny as the startup sound starts playing repeatedly!· Actually one of our staff said it was kind of annoying, but it was funny nonetheless.· Her unit is now connected to a wall-wart through a regulator.
Chris Savage
Parallax Tech Support
csavage@parallax.com
FOR J = 70 TO 127 'SOUND DEMO
SOUND RB.7,J,2
NEXT
Thank You
David Winchell
David@Winchell.com
·· ...And miss the confused looks I get when someone carries a dying medal over thinking it's broken?·
Chris Savage
Thank You
David Winchell
David@Winchell.com
Where is the picture of your SX-Key ring? (I missed it, could you post it again?) And they just take 6v (that you are giving through the servo cable, correct?)
I can't wait until these get here so I can play with them. I had thought about using them as 'eyes' also...
It would be fun to try and connect two of them for a continuous scroll....
Ryan
·· Actually I programmed 3 or 4 that are running around Parallax now...Mine changes messages daily.· There are about 4 people who have them running...I tested your home-brew SX-Key Ring.· BTW, I managed to scrounge an actual SX Key Ring and there is a small difference...The original does not supply power to the device, just the SX Key.· I tested the one you sent Jim.
Chris Savage
Thank You
David Winchell
David@Winchell.com
Bean.
www.sxvm.com
