EB500 connection status question
Hi all
I need to know what is the best way to check the connection status of pin 8 of the eb500.
the users manual ·states that it is a ttl output how ever all 12 of my·eb500's ·put out a 2.75v signal for high· and the pic i am using is not seeing that as high.
Lee
Lee
is there a chip that converts 3.3v logic to 5v ttl and back.
i need 5 lines
A quick search of interfacebus.com shows the following recomended interface: http://www.interfacebus.com/Design_Translation.html#i
its an octal transceiver for $.90 @ digikey in 24 soic and 24 ssop packages, goto www.sparkfun.com breakout board section to get an SOIC or SSOP to DIP adapter board for under $3 if you need dip format to prototype it, just get the 28 pin version and leave the other 4 pins unused
Post Edited (Paul Baker) : 3/4/2005 10:13:58 PM GMT
I am concerned that you may be suffering from voltage sag, your not trying to operate 12 eb500s off the stamp regulator are you? They will absolutely require thier own power. Thier total power requirement is 420mA. Since you posted in the robotics forum, are you running them off a battery? If so, check the voltage before the regulator (straight across the batteries) If this value is much lower than the batteries rated voltage, your drawing too much current from them.
Rick
the battery source is 48v 50A using a dc to dc converter for each pic , offering it 9 v at 1000 ma power source
thank you for the reply.
