ADXL202 Analog output
Does anyone used the analog outputs of the ADXL202 accelerometer?, Are they as fast as the PWM outputs?
I'm working in an application which needs very fast readings to determine tilt in one axis and I saw a lot of noise in the PWM outputs. Maybe that noise was because of the resolution of the pulsin command and the solution can be to use the analog outputs with an ADC and stop dealing with the PULSIN command.
What is the output?!· A varying voltage level?
Steve
http://ca.geocities.com/steve.brady@rogers.com/index.html
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
