Light on light of — Parallax Forums
Light on light of
RobeRobe Posts: 13
edited 2005-02-27 08:40 in BASIC Stamp
Hello every one
i am trying to turn a led on, off· wiht···a ·signal to the same i/o
one time for on one time for on· and so on.
Could you·please help, ·so·far i got· this
do
if in0 =1 then
high 5
pause 1000
else if in0 = 1 then
low 1
pause 1000
end if
loop
  • Robert SchwartzRobert Schwartz Posts: 141
    edited 2005-02-26 05:49
    Your IF statement doesn't really make sense. The ELSE IF will never be triggered since it has the same condition as the IF statement preceding it. I think that this is what you are trying to do:
    LedControl var 0
    LED var 1
    Start:
    DO
    IF LedControl = 1 THEN
    HIGH LED:
    PAUSE 1000:
    ELSE IF LedControl = 0 THEN
    LOW LED:
    PAUSE 1000:
    ENDIF
    LOOP
    END
    This will change the LED's status (on or off) depending on whether or not PIN 0 is high or low.
    Could you please explain your problem?
  • RobeRobe Posts: 13
    edited 2005-02-26 06:15
    Firts thank you for replying
    i am sending a high signal to the stamp to turn the led on
    then another high signal again to turn it off and another high signal
    to turn it on again, and so on i am trying to turn led off and on
    with the same high signal to the same i/o over and over again.
    edited 2005-02-26 07:17
    The you need something more like this...
    LOW 1
    Start:
    DO
        IF IN0 = 1 THEN          'Check for P0 to go HIGH
            TOGGLE 1               'TOGGLE Output pin P1
            PAUSE 1000            'Pause for 1 second Debounce
            DO WHILE IN0=1     'Wait for P0 to go LOW (Release)
            LOOP
        ENDIF
    LOOP
    END
    Beau Schwabe - Mask Designer III
    National Semiconductor Corporation
    (Communication Interface Division)
    500 Pinnacle Court, Suite 525
    Mail Stop GA1
    Norcross,GA 30071
    Post Edited (Beau Schwabe) : 2/26/2005 7:22:52 AM GMT
    Thank you so much
