eb500 and Javelin code samples
Does anyone have any code samples showing how to use the eb500 and the Javelin together? Are they posted somewhere and I'm just not seeing them?
J. Stepanek
J. Stepanek
import stamp.core.*; import stamp.util.*; /** * Bluetooth EB500: ruff demo. * * @version 0.0 5/2/04 * @author Tim C */ public class TestBlue { final static char HOME = 0x01; final static char CLS = '\u0010'; // Clear Screen final static char CR = 0x0d; // CR final static char LF = 0x0a; // LF final static char BUFFLEN = 40; final static char RDELAY = 15; // receive delay final static char EXPECTDELAY = 1; // seconds for rxUart final static int SERIAL_TX_PIN = CPU.pin1; final static int SERIAL_RX_PIN = CPU.pin0; final static int CONNECT_STATUS = CPU.pin5; final static int COMMAND_PIN = CPU.pin6; //static Timer tTimer = new Timer(); // used to end waiting for rxUart static StringBuffer buf = new StringBuffer(BUFFLEN); static char tempChar; static Uart rxUart = new Uart( Uart.dirReceive, SERIAL_RX_PIN, Uart.dontInvert, Uart.speed9600, Uart.stop1 ); static Uart txUart = new Uart( Uart.dirTransmit, SERIAL_TX_PIN,Uart.dontInvert, Uart.speed9600, Uart.stop1 ); static void getblue(boolean prt){ buf.clear(); while ( (tempChar =(char)rxUart.receiveByte()) != '\r' ) buf.append(tempChar); if (prt){ System.out.println(buf.toString()); buf.clear(); //assume buffer should be destroyed since printed } } static void printprmt(boolean prt){ buf.clear(); tempChar = '*'; do { while ( (tempChar =(char)rxUart.receiveByte()) != '\r' ) { buf.append(tempChar); if (tempChar == '>') return; } if (prt){ System.out.println(buf.toString()); buf.clear(); //assume buffer should be destroyed since printed } } while (tempChar != '>'); } static void blueCommand2(String me, boolean prt){ // using soft and gaining a pin but is slower boolean b; int x; if (CPU.readPin(CONNECT_STATUS) == true){ if (softbufMode() == false) { System.out.println("Failed: Switch to buf mode\r"); return; } } buf.clear(); txUart.sendString(me); txUart.sendString("\r"); if (Expect.string(rxUart, "ACK\r", EXPECTDELAY)){ printprmt(prt); }else{ System.out.print("buf: "); System.out.print(me); System.out.println(" Did not ACK!\r"); } if (CPU.readPin(CONNECT_STATUS) == true){ txUart.sendString("\r"); // seems to work better than examples in book } } static void blueCommand3(String me, boolean prt){ // using hard switching between modes usws a pin but is faster boolean b; int x; if (CPU.readPin(CONNECT_STATUS) == true){ if (hardbufMode() == false) { System.out.println("Failed: Switch to buf mode\r"); return; } } buf.clear(); txUart.sendString(me); txUart.sendString("\r"); if (Expect.string(rxUart, "ACK\r", EXPECTDELAY)){ printprmt(prt); }else{ System.out.print("buf: "); System.out.print(me); System.out.println(" Failed"); } if (CPU.readPin(CONNECT_STATUS) == true){ CPU.writePin(COMMAND_PIN,true); CPU.delay(50); } } static boolean softbufMode(){ CPU.delay(20000); //2 secs txUart.sendString("+++"); CPU.delay(20000); //2 secs txUart.sendString("\r"); if (Expect.string(rxUart, ">", 3)) return true; else return false; } static boolean hardbufMode(){ CPU.writePin(COMMAND_PIN,false); txUart.sendString("\r"); if (Expect.string(rxUart, ">", EXPECTDELAY)) return true; else return false; } public static void main() { char data; if (CPU.readPin(CONNECT_STATUS) == true){ System.out.println("Currently Connected"); blueCommand3("dis",true); }else System.out.println("NOT Currently Connected"); if (CPU.readPin(COMMAND_PIN) == true) System.out.println("IN Data Mode"); else System.out.println("IN Command Mode"); blueCommand3("get addr",true); blueCommand3("ver all",true); blueCommand3("lst 15",true); blueCommand3("con 00:0B:0D:21:46:FD",true); System.out.println("Listening..."); getblue(true); // puts sent data into buf and prints till enter System.out.println("*** Test FINISHED ***"); }That was a very quick reply. This code sample should be very helpful.
Thanks again.
J. Stepanek
