110vac to 5vdc
does anyone have any experiance with small scale ac dc conversions? i only need about 200mA. i know i can get a wall mount power supply but i would much rather incorporate the supply into my application.
League Bowling.... it's not a sport, it's a way of life
·· You didn't specify voltage, so I'll guess you meant 5V.· If you want to build your own on-board supply, you could buy the following at Radio Shack (Or pilfer them from something else):
About $15.00 in parts and could easily be mounted on a PCB taking up very little real-estate.· If you think you might ever need more than 200mA, for just a couple of dollars more you could use transformer (273-1365) at 450mA, or (273-1352) at 1.2A (The regulator will only give you about 1A though, and you'll need a heat sink).
If you have any questions about how this all gets hooked up, let me know.
--==<{Chris}>==--
bugg
Geordi: "It's like the laws of physics went right out the window!"
Q: "And why shouldn't they, there so inconvinient!"
Geordi LaForge, Chief Engineer, USS Enterprise, NCC 1701-D
Q, Omnipotent Prankster
