Mmc to serial adapter link
http://homepage.ntlworld.com/seanellis/mmcserial.htm
OVER THE PAST YEAR OR MORE SEVERAL HAVE EXPRESSED INTEREST IN THIS VEIN.
HOPE THE HELPS OUT
73
SPENCE
K4KEP
HOPE THE HELPS OUT
73
SPENCE
K4KEP
David
HAVE YOU LOOKED AT THIS.
http://www.ghielectronics.com/ALFAT.htm
THE DEV BOARD IS OUT NOW AND THE SD/MMC BOARD SOON.
I AM PLANNING ON GETTING THE DEV BOARD VERY SOON.
73
SPENCE
K4KEP
But I also like the challenge of getting my own design working, and I'm so close. I've got a working MMC/SD card interface from a Delphi PC program thru the parallel port to the card. I've got an SX board with card socket built, and just last weekend got its VP-style RS232 IO working. All it needs is the Delphi card interface code translated to SX code and it will be a working logger.
On the other hand, $50 for a complete MMC/SD board isn't bad. What to do...
David
(KM6VI)
If you use the "URL" formatting button before and after the ULR itself, the URL becomes a click-able link in your post. They look like this:
instead of plain text like this:
Just a nice thing to do for the rest of us so we don't have to cut and paste to check out the site...
Thanks, PeterM
--==<{Chris}>==--
Jim
I don't seem to have that capability in netscape 7.1. Fed dhs had us all get off of ie because of security problems. Have to do with what i have.
73
spence
k4kep
Smart move on their part. There are two ways to tag a url in a non-ie browser. If you click the "Reply" button instead of using the quick reply you will get a message entry box. Above the box will be buttons for various features, or at least in Firefox 1.0 there is. When you want to include a url, click the url button. This will insert '[noparse][[/noparse] u r l ]', without the extra spaces. Next type, or paste in the url. Entering 'http://' isn't necessary. Then hold the shift key down and click the url button again. This will insert '[noparse][[/noparse] / u r l ]'. So your entry will look like:
[noparse][[/noparse] u r l ]www.foobar.nowhere[noparse][[/noparse] / u r l ]
again, without the extra spaces.
Or, you can just type the begin and end tags yourself. I've gotten to doing that because it is faster for me to type them than it is the find the #^@$^*@ button.
Jim
--==<{Chris}>==--
