SX and PS2 Keyboards — Parallax Forums
Guenther DaubachGuenther Daubach Posts: 1,321
edited 2005-02-24 01:28 in General Discussion
Hi,
did anybody come across some SX code to interface to a standard PS2 keyboard. I think I once saw such application but I can't remember where and when.
Let me recite Clint Eastwood in Space Cowboys: "The clock's ticking, Bob - and I'm only getting older..."
Greetings from Germany,
G
  • ForrestForrest Posts: 1,341
    edited 2005-02-23 18:03
    There's an SX to PS2 interface on the XGameStation along with a program to read the keyboard in Chapter 11 - which is a free download at www.xgamestation.com/view_hot_download.php?id=3
  • Beau SchwabeBeau Schwabe Posts: 6,574
    edited 2005-02-23 18:46
    G
    edited 2005-02-23 19:59
    Forrest,
    I KNEW that I saw it somewhere, I have XGS chapter 11 on my hard disk. As I said before - I'm getting older smile.gif - thanks for leading me the right direction!
    Beau,
    yes, this is the opposite direction but you never know what it is good for.
    I once had a project to interface a bar code scanner to a PC, and one idea was to build an adapter that converted the incoming scanner data via RS-232 into PS2 compatible serial data, and merge them with the codes coming from the keyboard. Finally, it turned out that I could do this on the PC by software, i.e. reading the scanner via RS-232, and then sending appropriate events into the Windows message queue. Thanks a lot for your offer - I'll come back to it when necessary.
    G
  • James NewtonJames Newton Posts: 329
    edited 2005-02-23 22:13
    http://www.sxlist.com/techref/ubicom/lib/io/dev/keys/picboard.htm
    James Newton, Host of SXList.com
    james@sxlist.com 1-619-652-0593 fax:1-208-279-8767
    SX FAQ / Code / Tutorials / Documentation:
    http://www.sxlist.com Pick faster!
    James,
    this is great stuff (much more than I really need). Nevertheless, it again shows how much valuable information is available in www.sxlist.com!
    G
