What is a dremel good for?
I got a top of the line dremel for christmas, I used it for the first time today to cut enclosure openings in 1/16" aluminum. On the lowest speed the dremel got very hot after only a few seconds, forcing me to to set it aside to cool down. After about an hour of this process, the stator froze to the commuter. I did the "don't force the cut" technique letting the cutting wheel do the job. If the dremel can't handle even short periods at its lowest speed without self destructing what is it·good for?
I use mine for plastic and such...wood sometimes.
is yours a Dremel model or a clone?!
Steve
http://members.rogers.com/steve.brady
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
--==<{Chris}>==--
Harry
Now with the Dremel, the bits become dull after about 100 holes and I almost never break one.· It's a great tool.
Suggestion: Buy the cutting wheels that are fiber-reinforced instead of the ones that shatter.· It's much safer and they last alot longer.
Also, when drilling thermoplastics, use the lowest speed to prevent melting the material.· Otherwise you get a larger hole than you intended.
After seeing just how quickly it cut through the wire I made certain to buy a lock with thicker wire afterwards...
And yes, low speed/high torque is bad. Even though your power output might be higher at high speed/moderate torque, the fan (which is turned via the motor) will still be turning much faster, and cooling the motor more effectively.
Dave
Jim
Jeff
Ouch!!! .....Just remember to "steady" that sideways cutting bit or else....Ahhhhh!!! I don't even want to think about it.
Beau Schwabe - Mask Designer III
National Semiconductor Corporation
(Communication Interface Division)
500 Pinnacle Court, Suite 525
Mail Stop GA1
Norcross,GA 30071
Paul
(Is ticked he coupldn't complete the project in time for the deadline, stupid WinCUPL and the damn fitter program don't play nicely with each other)
