Short Circuit
I am trying to use the BS2 as a switch.· Say have P0 and P1 create a short circuit with about 1.5uA (micro amps) going through it and potential of about 76mV.· I would like this to be done programmatically, hopefully without having to use a bus switch or something like it, otherwise I know how I could use a bus switch. ·I have 5 lines that can short to a possible 8 lines for 40 combinations.· Any help would be appreciated.
http://www.maxim-ic.com/[noparse][[/noparse]url]
Rick
http://www.play-hookey.com/digital/multiplexer_two_input.html
AG
The TI SN74CBT3125D can be driven by a Stamp, but a Stamp can not act in manner to replace such a device directly. Among other things, that device will support a constant current of 125 mA which is far in excess of what the Stamp current rating is.
The SN74CBT3125D is esentially nothing more than a transistor array. In fact, the Stamp uses a transistor array in its construction but it can not be used separately.
Bruce Bates
AG
