ADC0831 analog-to-digital converter question
In the StampWorks article about using ADC's, there is a variable resister attached to pin 2 (Vin +). I was wondering what this is used for, and how I know if it set to the right level of resistance. Thanks.
http://www.parallax.com/dl/docs/cols/nv/vol5/col/nv114.pdf
Jon Williams
Dallas, TX· USA
In the article I suggested, the output from the sensor is always less than 2.55 volts. By setting the Vref voltage to 2.55 volts, this makes each bit of the output worth 10 millivolts; hence makes the program math easier to deal with.
Jon Williams
Dallas, TX· USA
Jon Williams
Dallas, TX· USA
Post Edited (Robert Schwartz) : 2/17/2005 3:25:06 AM GMT
Jon Williams
Dallas, TX· USA
