Flexinol 'Muscle Wire'
Having read the books about the Stiquito robot, I decided to build one. This robot has so-called 'muscle wires' made of a nickel-titanium alloy called nitinol (trade name Flexinol) which contracts when heated by passing a current through it. Nitinol has many medical uses, including making 'stents', small mesh tubes which expand in coronary arteries to reopen·narrowings.·There is a new book coming out about a microprocessor controlled version of Stiquito and the other books mention using a Basic Stamp to control the current via a Darlington array. This made me rather rashly invest in some Flexinol and Stiquito kits for a project to build a stamp-controlled 'muscle wire' walker.
I don't know if any of you have tried building a Stiquito. It is a nightmare! Think of precisely placing knots in·several short·strands·smaller than·the finest human hair and then crimping it in tiny sections of small aluminium tube. Finally, after many a 'robust expression',·I took to using·some microsurgery equipment (in electronics it helps to be medical - artery forceps·make excellent heatsinks for example) and built the damn thing·over three frustrating evenings. I now have a tiny feebly twitching 'stick insect' which walks precisely nowhere as it cannot grip any surface and overcome its own inertia. It is an understatement to say that it was a great disappointment.
So before I decide whether to even bother to try anything more, I should be interested in any other experiences with this curious metal, particularly anything positive!·Otherwise, I will not pursue it further.
Manxstamp,
Isle of Man, British Isles
Manxstamp,
The stuff is fascinating and I think it has tons of potential in robotics, but it's not for the faint of heart or the far of sighted. [noparse];)[/noparse]
Manxstamp, I would encourage you not to quit on it now, now that you know what this tempermental stuff needs to make it work. You have so much invested in the learning curve already!
Bruce
Work:· Clemensb@otc.edu
Good Stuff on my Bolg: http://theDeadBug.journalspace.com
Anyway, if you wanted to, you might be able to use conductive epoxys or metal filler to hold the nitinol in place instead of crimps, and hopefully the epoxy is stronger than the nitinol.
Justin W.
If you want to try, I will send you a kit for free.· Please send me your mailing address.
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
www.parallax.com
