Unused Pins on BS2P-24- What to do with them???
What is the best practice for terminating unused I/O pins on the Bs2P?
Tie them all together and pull them UP using a 10K?
Tie them all together and pull them DOWN using a 10K
Or tie them up / down individually using a 10K?
I have a stamp project where I am not using Pins 4 - 15. Just want to follow best practices.
Don
Post Edited (DChap) : 2/10/2005 9:09:39 PM GMT
Don
this applies to stamps as well. Safest is to use individual resistors, use a SIP bus resistor pack.
Beau Schwabe - Mask Designer III
National Semiconductor Corporation
(Communication Interface Division)
500 Pinnacle Court, Suite 525
Mail Stop GA1
Norcross,GA 30071
Good info in the link.
I will make them all outputs in software and tie them High.
BUT, can I tie all the pins together and route them all to +5v through 1 Pull Up resistor? I am out of space on my board.
If it were me I would do one or the other but not both... Either tie all inputs HIGH (or LOW)
OR
make all UNUSED pins outputs in software
Mail Stop GA1
Norcross,GA 30071
Making them Outputs in software is easy enough - done deal - and like I said, I don't have any real estate left on the board for Pull Ups..
Thanks again..
Don
Post Edited (Paul Baker) : 2/10/2005 9:43:50 PM GMT
