NASA rover uses BASIC Stamp
Tracy Allen
The "tumbleweed" rover is a 5 foot inflated ball that is blown around by the wind and relays its position and environmental data to the base station via satellite. One is currently deployed near the south pole of Antartica and the data is on line for us to see (That is, if they get the satellite link back up and running). Here is the link...
robotics.jpl.nasa.gov/~behar/southpoletw.htm#_1/2004:_South_Pole,
If you look near the bottom of that page, you can click on the image of the circuit board and see the BS2p40 module, the sensirion tempeerature/humidity module, the acceleromeer, the air pump, etc etc.
Tracy Allen
www.emesystems.com
Tracy Allen
www.emesystems.com
But I wonder about the design, though....
Why are they using Ni-mh rechargeables on a 'one-shot' system?
Not only won't these things get near any chargers once they are released, but how well does Ni-mhs tackle cold weather?
They're not the best choice when it comes to power/weight ratios, either.
Nice to see a BS2 in action, though.
I don't know. For what they are doing it makes sense. Sort of. Especially since the Poles match the perfect examples of what to find on Mars. What the things find wandering around will enable the agency to build better sats for exploring Mars.
Buck Rogers
www.gregg.levine.name
Also, NiMH's are better than alkaline's at low temp.
Dave
http://robotics.jpl.nasa.gov/~behar/southpoletw_files/IEEEAeroConf2004TumbleweedBehar.doc
You really don't want to take it apart after you're done testing it to replace the batteries, cause after you reassemble it you'll need to test it again. Then take it apart to replace the batteries...
Rechargables let you top off the cells right up till deployment.
Tracy Allen
www.emesystems.com
Solar panels are just too fragile.
(Either that or too heavy)
As for tumbling...
The only system I could imagine is something like the Seiko 'kinetic' system, which is a small weighted fly-wheel, but the weight and size of the fly-wheel dictates the max amount of power you can get out of it.
I wonder if anyone sells parts that can be used like that?
(I like to tinker, and I could use a powersource like that in my cayak...
As for disassembling it to replace cells...
And you wouldn't need to do that to recharge them?
High-current needs -- the air-pump motor, probably the Iridium transmitter. (And isn't it cool, after all this time and Motorola's "failure", that the Iridium system is still up and running! It's really the only way to talk to the poles.)
Regarding the Iridium transmitter, Motorola didn't fail on them. The company itself did. They failed to have Motorola include a cellphone as part of the design. In fact I suspect the designers at Motorola are, or were, at fault.
But yes, your right they are the only way to communicate with the poles, when it comes to hardware working up there.
Buck Rogers
Shake them for 30 seconds (a weight slides up and down in side the handle) and they power a blue LED for a minutes or so. It is bright enough to read. Weight is about 400grm.
haha. Does anyone have a working link to the picture? google didn't turn up anything either.
Man if NASA is using BS's then what am I doing fixing projectors? I want to program space robots...(really...that is my career goal. I need to go back to school...lol)
