Interrupt possible?
I am using the Basic Stamp 2 for a cleaning robot project. I would like to know if a interrupt is possible of some other method of being able to detect quickly if one of 5 microswitches are detected and perform a specific routine. I would also like to be able to give priority to specific buttons. If this is not possible I have to resort to a PIC microcontroller...
Rubenes
Post Edited (Ruben Jacobs) : 1/31/2005 6:19:59 PM GMT
Rubenes
The BS2 has no hardware interrupts, and in general its software is single-tasking. However, Jon can show you a technique to implement a form of multi-tasking in the PBasic environment. This requires 'sampling' the signals of interest -- the BS2 can implement a sampling algorithm with a latency of less than 10 mSecs. Latencies of less than 1 mSec can be done with the BS2, but less than 100 uSec would be impossible.
Basically, the approach has a 'main loop' which samples the signals of interest. Based on the samples, the 'main loop' calls subroutines to do the actual work, and the 'main loop' can maintain a state_variable to run a state machine in code.
Main: GOSUB Scan_Switches ON task GOSUB Task_0, Task_1, Task_2, Task_3 GOTO Main
As you can see, the program is broken into small tasks.· Between each task the Scan_Switches subroutine is called and can be dealt with.· Each task takes care up setting the next task, letting the program run in order, or if needed, in a new order to handle events that come up.
Jon Williams
Dallas, TX· USA
P.S.: Do you have any circuits to debounce switches? The BUTTON instruction is not very flexible.
Switches VAR INL ' switch inputs on P0 - P4, active-high swStatus VAR Byte idx VAR Nib ... Scan_Switches: swStatus = %11111 FOR idx = 1 TO 5 swStatus = swStatus & Switches PAUSE 5 NEXT RETURN
This routine scans all the switch inputs and if any stays active for the entire cycle (~25 ms), then it will be reported as active.
Jon Williams
Dallas, TX· USA
However, the BS2 solution will be simpler and easier to code and debug. It's up to you at this point. 1/2 second is 500 mSecs, which is a Long time to the BS2.
Thank you. I will see if I can get some software programmed.
Jon Williams
Dallas, TX· USA
