Car Seat Motors and Basic Stamp
I am trying to make a seating platform using car's seat motors. Basically, trying to make a 3-DOF. I know the motors are 12v driven.· Can anybody reccommed what the best route to take to interfacing with BS2. Has anybody done anything like this. Please provide any ideas, pointers, etc.
Really appreciate your help
thank you
nagi
MCP|MCAD|MCSD.Net
http://nagi.crosscity.com/
http://fstop.crosscity.com/
thank you
nagi
MCP|MCAD|MCSD.Net
Jon Williams
Dallas, TX· USA
thank you for your reply.
Paul,
I believe these are std gearbox DC motors and I believe they have 3 wires (possibly for reversing). I am still a beginner in electrnics; so I may not speak the right jargon.
Any help would be appreciated.
thank you
nagi
MCP|MCAD|MCSD.Net
Same as window motors. Just the fact that the motors are using such a amount of gear reduction would not require any brake to hold in position.
Just guessing, but those motors probably spike 40 amps on start up and probably pull 10 amps running. Using something to switch the motor would have to be pretty robust!
Unless you use a good ol' relay.
http://www.paysonarizona.net/
http://www.interfacebus.com/Design_Connector_LIN_Bus.html
Auto makers are migrating toward using a 3 wire (Power, com and GND)·serial communication network to interconnect controls and sensors.··This minimizes and simplifies wiring·accessories by sending control signals over a common·serial network rather than direct point to point wiring of switches.
As a result you need not only a physical interface for the LIN specification such as a Motorola MC33399 but also need to have the proper address and control codes to·communicate with the device.·· (The device could be an actuator or a sensor·)
A clue to weather this is so is the end application .·· A seat motor in a vehicle which remembers seat position and stores presets is more likely to be a LIN enabled device vs a vehicle which uses just a switch to move the seat.
Would it actually have all that inside the motor or just send pulses back to the seat control to "count" it's movements and memory? Interesting.
I've got my '03 Dodge 4X4 which I plan on keeping even when it's paid off. It's so easy to take apart that I mod things for the heck of it. Only motors in it are the windows and the other usual stuff.
Our '04 Dodge Grand Caravan has motorized everything which will be the vehicle we keep trading in after each few years because I know that stuff will break and it's no fun to take apart like my truck is.
Got motorized side doors, rear hatch, driver seat, and the foot pedals. But the seat and pedals have no memory. Just switches.
Still, the wife generally drives that and it's a lazy persons ride. Hit a button and any of three doors will open or close fully.
Some LIN devices go into a diagnostic mode when a Master is not detected within a few seconds. For a sensor this would mean that it would output a PWM signal instead of a LIN protocol serial output. A dewpoint sensor which sends Temperature, Relative Humidity & Dew point info over LIN will transmit the Dewpoint as a 10% to 90% Pulse Width Modulated output.
An Actuator might require a trigger to go into diagnostic mode. (You would want the seat of mirror to move just because communication was lost with the master)
This could mean holding the signal wire (third wire) at Hi, lo or 50% for 10 - 20 seconds or so with a pull Up/Down resistor to enter diag mode and activate the motor for example. A service manual and schematic for the seat might give you a clue.
http://www.geocities.com/jimforkin2003/index.html
