How to get 5V from a Tab SumoBot powered by (4) AA batteries
What's a good circuit to get a stable 5V from a Tab SumoBot powered by (4) AA batteries? I'm currently using a regulator diode to drop the battery voltage from 6V to 5.3V, which is good enough to drive a HD44780 based LCD. But when the servo's kick on, this voltage is reduced from 5.3V to 4.8V. While this is within the specs of the LCD (5V +/- 10%) - I can't believe this is good for long-term use. While the Tab SumoBot is driven by an embedded BS2, Vdd is not available on this robot. The BS2 is driven by Vcc regulated to 3.9V - which isn't high enough for the LCD.
However, to your problem. I don't think the low voltage on the LCD will hurt it. You could add a large-ish capacitor (100 uF?) to get through the power-spikes from the motors. And they are DC motors on the Tab Bot, not Servo's.
Another solution would be to add a 2940-5 regulator to the LCD power circuit, instead of the diode -- but the diode probably wastes less current.
http://www.hut.fi/Misc/Electronics/circuits/vga2tv/psu_5v.html
The 7805 in that circuit can source 1 amp with a heat sink and airflow.
You could also feed it with a wallwart.
You could then simplify the dual power source with a "steering diode" to save on batteries
Post Edited (Jonb) : 1/27/2005 12:00:37 AM GMT
-Ben
