Just a little more help
I'm sure the BS2 can do this, but I just want to check before I get too deep into reading the manual on how to program. I have a 4-bit binary code that I want to input into an I/O of the BS2, and depending on the code that is·input , I want it to toggle 6 different outputs. Does anyone have any examples on how this code would look?
Thanks again,
Ufaded
Thanks again,
Ufaded
After you've got the code the rest is easy.
Jon Williams
Dallas, TX· USA
Thanks again
Jon Williams
Dallas, TX· USA
Ufaded
' {$STAMP BS2} ' {$PBASIC 2.5} Switch VAR INA Leds VAR OUTH idx VAR Nib Reset: DIRH = %00011111 ' make P8 - P12 outputs Main: idx = (NCD Switch) - 1 LOOKUP idx, [noparse][[/noparse]%00011, %00001, %11101, %00010, %11110], Leds GOTO MainWith this little program the outputs (LEDs) will only change when a matched input is made.· Note that you are using four pins to get four selections; you could use two.
Jon Williams
Dallas, TX· USA
Thanks for your help.
Jon Williams
Dallas, TX· USA
