Conversion of Byte to 8 Bits
What's the easiest and quickest way to convert from a byte variable to its 8 bits in a BS2?
For example, I have the following:
MyByte VAR BYTE
MyBit0 VAR BIT
MyBit1 VAR BIT
MyBit2 VAR BIT
MyBit3 VAR BIT
MyBit4 VAR BIT
MyBit5 VAR BIT
MyBit6 VAR BIT
MyBit7 VAR BIT
I want to be able to set MyBit0 through MyBit7 to equal bits 0 - 7 respectively of MyByte.
Thanks!
MyByte VAR BYTE
MyBit0 VAR BIT
MyBit1 VAR BIT
MyBit2 VAR BIT
MyBit3 VAR BIT
MyBit4 VAR BIT
MyBit5 VAR BIT
MyBit6 VAR BIT
MyBit7 VAR BIT
Thanks!
thing· var· byte
thing0 var thing.bit0
thing1 var thing.bit1
thing2 var thing.bit2
and so
Now you have 8 variables corresponding to the 8 bits of thing byte.· You can now assign values to those bit variables.
Sid Weaver
Do you have a Stamp Tester?
http://hometown.aol.com/newzed/index.html
myByte = 0
myByte.BIT3 = 1 ' myByte now holds 8
You can also index through the bits of a variable.
FOR idx = 0 TO 7
· myByte.LOWBIT(idx) = 1
NEXT
(Silly example, I know, I simply wanted to demonstrate the use of the LOWBIT() modifier)
Jon Williams
Dallas, TX· USA
So if I want to get bits 0 - 7 of a byte variable I can just do this:
myByte VAR BYTE idx VAR BYTE myByte = 85 for idx = 0 to 7 if myByte.LOWBIT(idx) = 1 then 'do something here... endif nextJust to confirm, in a byte variable, you would always use LOWBIT, but in a word variable, you could use LOWBIT and HIGHBIT, correct?
I could also do this then per Newzed:
If I was concerned with the code overhead time of LOWBIT (which I am assuming is higher than .bitx)
If I am correct here, this should suit my program nicely!
Thanks...John
Yes, using the LOWBIT modifier adds some overhead, but it also adds flexibility that you don't get with straight aliasing.
Jon Williams
Dallas, TX· USA
