Javelin Internals
If the Ubicom SX48AC is operating at 25MHz on the javeline stamp and has an average instruction length of 3 cycles, that makes the javeline roughly 1/1000 th the speed of native code on the Ubicom SX48AC. I recognize that there is an IC for doing bytecode translation to the native Ubicom SX48AC instructions and that there may also be some buffering involved assuming there is a pipeline in the architecture. I would think that this whole process would consume somewhere on the order of 20 to 50 cycles. Could somone explain why it takes roughly 1,000 cycles for a single java bytecode operation to process? I'm wondering what sort of optimizations could be done in a future version to make this more efficient. Also, why was the Ubicom SX48AC selected to run at 25MHz and not 50MHz?
Post Edited (Justin Shumaker) : 1/21/2005 5:11:16 AM GMT
Jon Williams
Dallas, TX· USA
1) Void your warranty
2) Upset the operation of the Javelin (everything is designed and timed for 25 MHz), causing it not to work
Jon Williams
Dallas, TX· USA
