Suggestions for Soldering Iron
I think my next investment for my robot hobby should be a new soldering iron.· I have a cheap $8 25 watt Pencil Iron from the "Shack".· I don't need to go crazy since this is just a hobby.· I use it for thru-hole work but could see myself starting to get into SMD at some point.· Any suggestions?· Do I need a variable temp?· Should it have a digital readout?· What are the better quality brands?
Thanks!
Thanks!
If you have it in the budget, go for a variable....it's nice to be able to crank it up for big jobs or lower it when doing sensitive work.
Or, a good all around pencil style is·a 35Watt Weller....definately make sure you have a 3prong plug (many don't have the additional ground plug).
Steve
http://members.rogers.com/steve.brady
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
The Xytronic 136ESD is a more moderately priced unit and·there is a used iron (only used during a tradeshow) here: http://www.howardelectronics.com/used.html·for $45, the only difference between the 136 and the 137 is that the 136 does not have a digital display.
I talked about these soldering irons and my method of doing SMD work in this thread: http://forums.parallax.com/showthread.php?p=522712. The nice thing about the Xytronic (though Im sure the Weller series has something similar) is the mini-wave soldering tip which was specifically made for hand soldering smd parts. Clicking on the solder tip link on the page for the 136 will get you there. Additionally Howard Electronics staff is very helpful and quickly answers any questions you have.
Paul
Jim
Again, thanks for your thoughts! Much appreciated.
p.s. I like the videos at the Howard Electronics site... it is actually kind of funny to think that the last video I saw before that one was when I rented I-Robot. I think the soldering video had better a better plot!
I have a RS-components branded one, and the three features I wanted in mine was:
1. Adjustable temperature(you need a thin screwdriver to do it on mine, but it works)
2. Fine tip...
3. Non-flammable power-cord...
(I have a tendency to hit the cord with the tip of the iron... )
