totem pole mostfet pair assistance
HAIL YOU GUYS....
can anyone recommend a good pair of TO-92 case mosfets that i can use in a totem pole driver circuit?
i've traditionally used 2n7000's for misc mosfet needs and i need a good match for the pole
that would be the rox
nick B
League Bowling.... it's not a sport, it's a way of life
nick B
The last totem pole I worked with was over a year ago and used a IRF230 & IRF5210 (TO-3 & To-220 respectively).
One thing to be aware of is that if your gate drive signal is slow to change or weak you may have both FETs conduct at the same time.. Pretty obvious if this happens as you will have very hot parts (& Possibly smoke). I had this problem when applying the ouput of a MC14050 inverter through s 2.2 K resistor to the gate... Ended up adding a 200ohm pull up to the gate as well which solved much of the problem.
Paul
On Semiconductor, MMDF2C03HDR2OSCT, 8-SOIC $12.35 (most expensive but only one to specifically say complimentary)
Toshiba, TPC8403CT, SOP-8, $.88
··········· TPCF8402CT, VS-8, $.92
International Rectifier, too many to list check this catalog page: http://dkc3.digikey.com/PDF/T051/0683.pdf
ST, 497-3232-1, 8-SOIC, $2.10
Diodes Incorperated, BSS8402DWDICT, SOT-363, $5.94
There are also matched npn/pnp parts but I didnt list them since your schematic specifies mosfet.
If you need through hole, digikey also sells smd to through hole adapters, let me know if you have a problem finding them and I'll point you in the right place.
Paul
