Anyone heard of the robomaid?
http://www.robomaid.com/
Saw the ad for this tonight, its a pretty simple design. For $10 I'm thinking of getting one and seeing if I can hack it and put my own brains in it, maybe·radio unit·too.
Paul
Paul
Jon Williams
Dallas, TX· USA
Of course if you just want to hack, it really is a heck of a bargain, but it doesn't automatically dock for recharge. I assume that it has no sense of home, just figures out how to keep randomly rolling.
G. Herzog in Taiwan
It's not very good at cleaning, and only changes direction when it bumps into something.
(That video does NOT show it in real operation)
Tests done here in Norway(Sorry, I don't remember by who) showed that unless the room was completely empty it'll leave large areas not cleaned.(The electrostatic charge only means it'll pick up loose dirt) The frame around the ball is also too light, so that it doesn't apply enough downforce to remove anyting but the loosest of the dirt.
Basically, it's a 'bump'n turn' child's toy withh a plastic frame around it...
Also, I know they sell them at a nearby store for NKr 160, about $20.
Auto charge would be an issue, but you could put a metal plate sensor network on it, with a controller that senses·when its on the charge plate. Haven't really though of that issue, but it may be solvable.
Post Edited (Paul Baker) : 1/10/2005 8:56:22 PM GMT
I assume they use a heavy weight in it(possibly the batteries) to keep the innards oriented one way.
If so, to charge, attach a small coil at the bottom of that(so that it will be facind down at all times) and another coil in the charging location. Then just let it roll into place... No exposed electric contacts on either. (A big plus)
Don't want to make the coils?
Some electric toothbrushes already have this setup. Just break one open and you have all the parts you need...
(It may have two motors - one for locomotion and one that spins a band that is parallel to the floor. The second one, the band, would torque the unit when it touches a surface and redirect its trajectory. No brains, all electro-mechanical.)
If so, there is really nothing to hack. You have an electric tennis ball, that's all. Heh, heh. . .
How would one ever get the thing to know where the charging station is?
Gadgetman's inductive recharger is very interesting though. I would love to hear more about that.
(I could put coils on the feet of my Toddler and have him do his own recharging.)
G. Herzog in Taiwan
I have an old Seiko Data watch from 1984, and it uses induction to connect to the external keyboard...
One drawback with using induction to transfer power is that it is difficult to dump high currents through it(we're talking about an 'air-filled transformer' with a large gap between the primary and secondary coils). It may also cause problems with compasses and such...
I wonder... Doesn't those robot lawnmovers also use induction to recharge?
go to www.robotstore.com and check out the OctoBot surviver robot.
bugg
So many projects, so little time.
